help~ 1995 gsr no spark~
Story-
It started randomly bogging in first gear, very little though and then it runs fine after. It recently bogged completely and refused to turn on again after that. I checked if the motor was getting fuel, it is. I checked for spark, and none of the cylinders are getting any spark. I changed the spark plug wires, and I changed the spark plugs. I also maybe need a propper diagram for my distributor cap and my spark plug wires. Do distributors just go bad out of no where? I've read about ignition coils going bad.. I've never had this problem before.
any help is appreciated, thanks.
Well, check if fuel pump works. put key in 2nd stage, you gotta listen to it. Check fuses if blown. This happened to me last week, I had to change ignition coil. It varies, could be a number of things.
well first so is your car not starting at all? or is it at least turning over. and if it is turning over like you hear it trying to start but no spark. the first place to start to check for problem is your distributor... first trying opening it and seeing if your rotor in the distributor not lose or maybe even off... if that fine take off your distributor and get it check to see if that good. cuz yes they do just go out without any notice that what happen to my girl car and had to change it...
itsm3paul
May 10, 2004 12:49 PM
