ls vtec question
Old Aug 23, 2009 | 11:36 PM
efchris's Avatar
Default ls vtec question
i have a 94 civic coupe with a ls in it with a gsr trans and the timing belt just broke luckily i have a spare complete b16 head but i need to know exactly what i need to run this head on my car. I know i need a golden eagle ls vtec conversion kit and a gsr timing belt and water pump but what else? I'm not going to be reving very high but idk what i can rev the stock block to safely. And i'm going to order an ecu from phearable.net for the tune then get it dyno tuned. thanks need replies fast i'm without a car right now.
Old Aug 23, 2009 | 11:39 PM
sayyoooon's Avatar
Default Re: ls vtec question
arp head studs will go a long way. as long as you're not beating the **** out of it everyday you should be fine with a stock block.
Old Aug 24, 2009 | 01:03 AM
98civdx's Avatar
Master Detailer
arp head studs, hoever the most important thing is the arp rod bolts, regardless of what its going to reved to,
arp rod bolts, you should be able to rev 7500 safely...
but dont push your luck, rods bolts are a good safty thing, but ls's wernt designed to rev to high.
Old Aug 24, 2009 | 01:45 AM
sayyoooon's Avatar
definately not designed to rev 9k's allday everyday.
Old Aug 24, 2009 | 01:46 AM
1988_96hb's Avatar
check the faQs. Theres threads called "everything you need to know about ls/vtec"
Old Aug 24, 2009 | 11:14 PM
efchris's Avatar
ya know with the time you took to say check the threads called everything you need to know about ls vtec you could of just said something helpful that i could of read and been like sweet now i don't need to ask anymore questions.lol sorry but thats everybody else.
yyourb0yy
Dec 12, 2012 06:42 PM
floridaboy56
Jul 16, 2008 04:50 PM
Novtecdohc
10
Jan 25, 2006 07:34 PM
Ekay Jay
Feb 7, 2005 05:44 PM
riceball777
Oct 22, 2003 07:56 PM
