just replaced my main bearings and rod bearings now engine wont move
Old Aug 23, 2009 | 12:54 PM
integra3586's Avatar
Default just replaced my main bearings and rod bearings now engine wont move
Any reason why my engine wont move after i replaced the main and rod bearings? Im pretty sure it has something to do with my rod bearings, but i torqued them all to spec, and in the correct steps.
Old Aug 23, 2009 | 01:03 PM
gourley's Avatar
Default Re: just replaced my main bearings and rod bearings now engine wont move
Did you plastiguage?
turbo_x's Avatar
New User
did u oil the crank and bearings?
bearings could be the wrong size.
Old Aug 23, 2009 | 01:08 PM
Circusraven's Avatar
Won't move, as in you're trying to manually turn the engine over and you can't? How much pressure are you putting down if so, you won't be able to turn the engine over without a small amount of force.
Old Aug 23, 2009 | 07:30 PM
silentkid's Avatar
plastiguage?
double check for correct bearing size?
rotated the crank after installing the fresh bearings?
and rotation after each rod install?
is it locked in place no movement? or turns a certain amount before stopping?
(this is assuming its not in the car yet wit ha no start condition)
Old Aug 23, 2009 | 07:40 PM
i did not plasitgauge. I was trying to just slap the motor back together. I wasnt expecting longevity. I used generic part store bearings. Ive given up on this motor, im just gonna put some POS motor in it. I just need something with good gas mileage
Old Aug 24, 2009 | 01:04 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Theres your problem. Wrong bearings
Old Aug 24, 2009 | 06:04 AM
jhammond_82's Avatar
Reject Papi
hm... i say take it apart and use some plastigauge.
Charlie Moua
Jan 16, 2012 07:01 PM
integra3586
19
Aug 25, 2009 09:31 PM
sixtodc4
Jan 20, 2008 09:33 AM
itr1244
May 19, 2005 07:40 PM
TheSwift1
Nov 12, 2002 08:12 AM
