tachometer,odometer,gas and temp gauge dont work
Old Aug 23, 2009 | 12:54 PM
jdmkris's Avatar
Default tachometer,odometer,gas and temp gauge dont work
i have a 95 civic dx with an lsvtec the tachometer,odometer,gas and temp gauge dont work but the back light to the cluster works fine..out of no where rpm needle and all other needles stopped working. hazard signals work on the cluster..but turning signals dont.I checked the fuses and they are fine.what may the problem be? thanks
Old Aug 23, 2009 | 12:57 PM
VEGAN_EG's Avatar
Default Re: tachometer,odometer,gas and temp gauge dont work
bad cluster???
loose wires? check the wiring that plugs into it, try another cluster if you can
Old Aug 23, 2009 | 01:02 PM
jdmkris's Avatar
ill see if i get another cluster tomorrow..checked the wires and they are fine
Old Sep 10, 2009 | 07:48 AM
96f22b2's Avatar
i have the same problem now with my turbo crx.. rpm guage and turn sigs stopped working over night. hazerds work though.
Shane96teg
Jan 28, 2013 04:10 PM
jdmsteveo05
Dec 31, 2006 01:04 PM
bubbakrip
Mar 29, 2006 09:37 PM
alexross
Oct 22, 2004 11:28 PM
