Transmission & Drivetrain Gearboxes, Differentials, Clutches
Locked out of reverse?
Old Aug 23, 2009 | 02:51 AM
sw1fty's Avatar
Default Locked out of reverse?
Hey guys
my car is '96 ej8 (d16y8) manual
i recently changed the bearings and seals in my gearbox since they were making bad noises. after putting it all back together and testing it i found that reverse would not go in no matter what i did, it just grinds
anyway so i had a search through this forum and found some possible problems. however i couldnt fix it doing anything that was mentioned in any of the previous threads... so i decided to take the gearbox apart again and see what the problem is.
the problem is with the reverse selector, it wont engage reverse unless i manually click the spring back. what am i doing wrong? from what i can see the selector can only go in one way??? is this wrong? any ideas?
ive attached pics and a short clip that will show what i mean.
cheers, Tom. P.S the actual reverse gear was taken out for the video
And video:
http://tinypic.com/r/33cugy8/3
Old Aug 23, 2009 | 12:19 PM
Aquafina's Avatar
Default Re: Locked out of reverse?
You put the reverse idler gear in upside down.
Old Aug 23, 2009 | 02:22 PM
Mista Bone's Avatar
D Tranny Guru
DOH!
Old Aug 23, 2009 | 05:22 PM
sw1fty's Avatar
so i tried turning the reverse gear around
at first it didnt work either but after a bit of playing around i got it to go straight in to reverse ... arg such an annoying mistake...
thanks for the tip guys, just saved me a lot of time
Tom
Old Aug 24, 2009 | 07:52 PM
Mista Bone's Avatar
D Tranny Guru
FIRST Honda tranny I ever watched being tore apart, the tech put reverse in backwards.
Swore I'd never do that!!!!!
I have put the 1-r-2 slider on upside down though.
DJ4Jesus77
Honda Civic (2001 - 2005)
10
Oct 8, 2010 08:57 PM
boosted92hatch
10
Feb 24, 2008 01:50 PM
soxfan143
Honda Civic (2006 - 2015)
10
Nov 14, 2007 07:07 PM
JDM_Type-R
Oct 23, 2003 06:10 AM
