help, my car just took the ultimate sh*t!
Old Aug 22, 2009 | 09:04 PM
patrickstar's Avatar
Default help, my car just took the ultimate sh*t!
ahhh here we go. so i just changed the positive battery terminal and i readjusted the battery holder. and i was driving and i smelled something. so i pulled over popped my hood and saw that the metal from the battery holder was touching my intake. i was like oh ****. and while i was moving it around it was sparking. i had no electrical tape to wrap the metal temporarily til i got home, so i adjusted it and i thought it was ok to go home. i was driving home and as i was pulling into my street, the car just started losing power and all my cluster lights were going on and dimming out. so i quickly stopped the car put it into neutral and turned the car off. took a while for the car to turn off but eventually died.
popped the hood, unhooked the ground cable to the battery and took the intake arm off. i saw the ground wire from my valve cover was fried so i didnt try to start the car again. so my question is, anything else i should check for? i will check all my fuses tomorow morning and where can i get that ground wire on the valve cover at? can this be an easy fix? sorry for the long explanation, thanks guys
Old Aug 22, 2009 | 09:38 PM
black88's Avatar
Default Re: help, my car just took the ultimate sh*t!
sux sorry to hear this! good luck
Old Aug 22, 2009 | 10:26 PM
yeah thanks man. im just hella worried cus my car was dying slowly and my lights were going crazy on me. this happened to anyone?
Old Aug 22, 2009 | 10:42 PM
xTimmyx's Avatar
actually yeah it happen to me one time, the positive terminal was touching the intake tube and it was arcing like u wouldnt believe, burnt a hole through the intake on the terminal to the other side of the intake, then it went into the strut tower and burnt a hole in there too.
i just went and grabbed some of those battery terminal plastic covers and popped it onto the positive terminal, ever since then nothing has happen.
oh yeah i had to replace the battery for sure too.
Old Aug 22, 2009 | 10:55 PM
oh wow thanks timmy! you gave me so much relief. hahah. i hope thats the case for me as well. did you get the plastic cover at a regular parts store? and did ur lights go effin crazy too? also, did ur ground on ur valve cover fry just like mine?
Old Aug 22, 2009 | 11:24 PM
xTimmyx's Avatar
i was only fortunate enough that it only arc'd through the intake into the tower, no wires were burnt at all. of course this all happen cause i had the "big 3" upgrade i did in the engine bay. so maybe thats why no wired were burnt.
yeah i just went to like canadian tire and got those plastic covers, put it between the positive terminal of the clamp and the intake, so it wont arc anymore.
this also happen during the day, i smelled something burning and the dash lights were turning on and off and losing power as i drove, then it all died. i always carry a digi multimeter in my car, so i checked the battery and sure enough it was fried.
Old Aug 23, 2009 | 12:13 AM
ohhh boy i hope ur intake wasnt an expensive one. and whats the "big 3"? oh and this might sound stupid, can i use any battery or do i have to get one specifically for my car? cus i always end up getting the battery for my car.
Old Aug 23, 2009 | 01:03 AM
xTimmyx's Avatar
Big 3. upgrading your ground wires from your valve cover to your chassis, your tranny ground to your chassis, and the power wire from your alternator to your positive battery post, i also upgraded the ground wire from the battery post to the chassis.
and i used 4awg wire for everything.
you can use any battery, but the big question is...is it going to fit? CRXs already have a small battery as it is. going any bigger, you'll prolly have to mod your battery tray or relocate your battery to the back of the hatch.
i really wanna get myself an optima red top or yellow top but those suckers are expensive as crap.
but the good thing bout those are they have the side posts so u dont have to worry bout arcing to the intake.
and my intake is not an expensive one at that. just a cheapo painted one.
https://honda-tech.com/forums/audio-security-video-27/power-wire-fuses-holders-%22what-size-do-i-need-%22-big-three-upgrade-pics-details-1952098/
^^^^ link if u wanna do the big 3 upgrade.
Old Aug 23, 2009 | 03:17 AM
yeah i always hear ppl talk about those batteries. i think im jus gonna get a regular battery for the ef jus to get the car running. thanks for the info though!
can i use any ground cable frm the valve cover to the chassis or isthere a specific kind? and i jus wrapped my intake arm with a crapload of elect. tape.
Old Aug 23, 2009 | 09:56 AM
-ok damnit, so i checked all my fuses. all good.
-i checked the connections and they are still in good condition. except my ground wire on my valve cover to the chassis. that thing is fried and it actually broke in two pieces. so basically no ground from the valve cover.
-i switched my working battery from my other ef into this one and tried to start it. same results. won't start
ok so the engine cranks and sometimes would start. sometimes the engine would just keep cranking and wont start. is it not starting because of ground wire on the valve cover? i need this car to start. lol.
also you kno when you install a working battery, when you hook the negative cable you get the usual sparks, i dont get that with my old battery. (i did though when i was putting in the working battery from my other car)
Old Aug 23, 2009 | 12:08 PM
xTimmyx's Avatar
a digital multimeter is ur best friend here.
i would also try and get some sort of ground wire from the valve cover to the chassis. even if u have to make one.
also put the key into the "on" position, and check if ur throwing a code on ur ecu.
u also wanna make sure that ur battery post isnt really near the intake, that or there's the plastic covering over top.
i would also check all your grounds too, especially the one to your thermostat housing. not just your valve cover ground.
there's so many variables that could be happening here man, just gotta rule them out one at a time.
Old Aug 23, 2009 | 12:13 PM
Gunmetal_B20_Hatch's Avatar
If your car died while driving then you may have killed your alternator...
Old Aug 23, 2009 | 06:11 PM
ok well i just put a new ground wire from the valve cover to the chassis. i just got a 10 awg and wrapped the wire around the bolt and bolted it down. hooked everything up. still nothing. it would crank and start and die. it would crank and nothing. and sometiems nothing at all.
in the on position, the cel isnt on. only the battery seatbelt and the regular stuff. also both my turn signal lights light up and stay on. when i click the hazard button, all i hear is a weird sound coming from the cluster or under my dash on the driver side. sound like a mechanical thing.
what would i do to the voltmeter? im taking my battery to the auto store to get it checked right now.
*edit: auto store closed. and the sound i coming from under my dash near my fuses. i think its coming from a relay. i dont know if its the main relay. its right above the fuses.
Old Aug 24, 2009 | 05:01 AM
89fodo's Avatar
happnd to my sedan as well countless times....just relocated batt :-) or wrap the intake with something
Old Aug 24, 2009 | 09:49 AM
sh!ft's Avatar
Who the fack changed my title?!
check all your fuses in the engine bay and under the dash, locate and check your relays under the dash if your car dosent turn on after you fix your problem and i used one of my spoon resivor cap covers and just put it around the area of my intake where it would always touch my battery, no probs after that
Old Aug 24, 2009 | 01:04 PM
alright guys will do. thanks for the suggestions. how many relays are under the dash, jus two? do i have to open up the main relay to check if its ok?
Old Aug 24, 2009 | 05:04 PM
89fodo's Avatar
should be able to listen to it when u turn the key on...when mine was going bad it made nasty noises and id have to hit it around to get it to work or buy a $45 relay lol when u turn the key on it should click once check engine light on then bout 2 seconds later will click again and check engine shoud go off if that checks out relay should be fine
Old Aug 24, 2009 | 10:26 PM
ooh ok well then i guess my main relay is fine then. lol thanks man. hmm im hoping its just a bad ground or something.
Old Aug 24, 2009 | 11:06 PM
oh and when i make a ground, can i just strip the wire and wrap it around a bolt and bolt it down? or do i need the little ring thing at the end?
Old Aug 26, 2009 | 10:41 AM
hmm tried starting the car up again today, and sometimes it would start and it would stay alive only if you keep on the gas. if you let the rpm drop , it dies. also all my cluster lights work except my fuel gauge doesnt work.
this happened ot me last time but everything in my cluster wasnt working, and it was only a fuse. the fuse looks good though. and i kno i put gas in. anybody have any ideas on that? thanks
patrickstar
Aug 24, 2009 12:25 PM
petty$rep
Feb 2, 2008 10:25 AM
fumpster
Dec 5, 2007 11:24 AM
mr.roboto
Sep 20, 2005 06:54 PM
hb_racer
Jun 16, 2004 08:05 AM
