tranny leaking a little, oh what to do?!
Old Aug 26, 2002 | 06:51 AM
hatchy's Avatar
Default tranny leaking a little, oh what to do?!
It looks like I am leaking a little transmission fluid from the half shaft hole (the hole where the half shaft connects to the tranny on the driver's side). Is there a seal there? And more importantly, can it be replaced without pulling the tranny?
How do you check the tranny fluid level? Do you just unbolt the fill hole and start pumping fluid in until it starts to overflow?
Thanks
Old Aug 26, 2002 | 06:58 AM
rbf351's Avatar
Default Re: tranny leaking a little, oh what to do?! (hatchy)
pull the axle and replace the seal
Old Aug 26, 2002 | 08:09 AM
hatchy's Avatar
Default Re: tranny leaking a little, oh what to do?! (rbf351)
Thanks rbf! Good to know that this can be done w/o pulling the tranny.
Old Aug 26, 2002 | 08:10 AM
hatchy's Avatar
So is there a way to check tranny fluid level without unbolting the fill bolt and pumping oil into it until it overflows?
Old Aug 26, 2002 | 08:27 AM
rbf351's Avatar
take the bolt out, the stick your pink into it, the luid should be sitting right at the top of there the bolt hole is
Old Aug 26, 2002 | 08:31 AM
hatchy's Avatar
thanks again
jdmstyleEJ6
12
Apr 2, 2010 08:07 PM
.one lane
May 2, 2006 05:38 AM
vtec25
Mar 16, 2006 06:54 PM
H22A4Me
Jan 27, 2006 07:55 PM
