FS: 2008 Lancer Evolution X Track/Show - Not a DD. Anaheim
Old Aug 22, 2009 | 12:42 PM
dc_TypeR's Avatar
Default FS: 2008 Lancer Evolution X Track/Show - Not a DD. Anaheim
I know this is a Honda forum, but I am trying to get the word out about this car, because you never know who is looking for a track/show car now-a-days.
(I've been a member here since 2004 Under DC2_TypeR) Don't post anymore, as I don't own a honda, and have been out of the scene for a while... but I plan on getting back in.
My plans were to turn this into a full track car, to compete in the Time Attacks ect, but I lost my job ¾ of the way into this project, and now I have no more money to invest into this car.
The history behind this car:
Purchased it from South Coast Mitsubishi 02/09/2008 Brand New.
Car currently has 719 miles on it. Street driven for 600 of those miles (break in period)
Car has had 2 oil changes. Both changes are with Redline oils.
All Differentials have been changed to BG Shock Proof.
Redline Fluid in the Transmission.
Redline Water Wetter and Water in the Radiator (If you are tracking, it stays the coolest)
Car is being sold “as is” and there is no warranty.
Vin # will be given to interested parties. It is clean, and can be covered with full coverage insurance.
Car is registered as Non- Op through the CA DMV... it will cost around $340.00 if I remember correctly to get tags for 2009
Car was featured @ SEMA 2008, in Seibon Carbons booth.
Car was also featured on www.carb8mag.com
The car has also been featured on a couple over sea European Magazines, as well as 1 Australian Magazine.
****Note****
As far as power levels are concerned... it could come 3 ways......
1.) E85 tune.. making above 450+ whp
2.) 91 tune..making around 410 whp
3.) NO Tune, and you tune it yourself
This is what the car is currently making @ 30psi on E85
The car has A LOT more left in the tune as well. We are going to switch to a free flowing 3" exhaust, and a different lower IC pipe, and we should be around the 470 mark all day long @ 30psi. This turbo is capable of flowing 35+ psi..just to give you an idea of its power capabilities.
Car will not come corner balanced, or aligned.
I can arrange to have it corner balanced and aligned for an additional $350.00
I’m washing my hands with this project, My loss, your gain, I want this car to go to a good home... to someone who is going to take this project.. and run with it... and take it to the next level.
If you were to take a base evo, strip it down, and do the mods I have, you would easily be in the high 60k range, without tuning and installation...
Base Evo- $28.000.00
Exterior :
Carbon Fiber Hood (oem style)- $560.00
Carbon Fiber Front Grill - $208.00
Carbon Fiber Fog Light Surround - $288.00
Carbon Fiber Lip (oem AERO style) - $400.00
Carbon Fiber Fenders (+10mm wide) - $675.00
Carbon Fiber Side Skirts (oem AERO style) - $560.00
Carbon Fiber Doors (front) - $1920.00
Carbon Fiber Doors (rear) - $1920.00
Carbon Rear Lip Spoiler (oem AERO style)- $400.00
Carbon Rear Diffuser - $480.00
Carbon Fiber Trunk - $608.00
APR GTC 300 Wing - $1079.00
Interior:
RaceTech RT1000 Seat (black, weighs 14.3 lbs) – $650.00
RaceTech RT Pro 5 Cam lock Harness (red) – $290.00
Custom Recaro Bracket w/ Slider - $180.00
Key!s Racing Steering Wheel (deep dish 350mm) – $339.99
Works Bell Rapfix 2 – $339.99
Works Bell Short Hub – $190.42
ARC Titanium shift **** - $123.67
Carbon Fiber gauge housing for Zeitronix LCD display, gauges, fabricated by Road Race Engineering
STRI Gauges DSD X line Smoked Lenses, Black face, white display (matches stock gauge cluster)
60 MM Oil Pressure Gauge - $97.00
60 MM Oil Temperature Gauge -$85.00
60 MM Water Temperature Gauge - $85.00
60 MM Voltage Gauge - $74.00
Zeitronix ZT-2 Stage Eleventeen (Boost, EGT, Wide Band, Black face LCD Display) - $560.00
10 Point DOM Steel Cage (N.A.S.A./SCCA Spec) 1.75” Tubing .120 wall - $3000.00
Professional built, and tig welded by Road Race Engineering
Interior and Roll Cage painted by DTM Autohaus , which is the sister company to M1 Autobody
15 feet of BSI SFI compliant black roll cage padding - $100.00
Brakes/ Suspension/ Wheels & Tires:
Stoptech 355mm Slotted Rotors/Red 6-Piston Calipers (Front) - $3195
Stoptech 335mm Slotted Rotors/Red 4-Piston Calipers (Rear) - $2595
Megan 32 way adjustable coilovers w/ camber plates (same **** as Apex)– $1010.99
Toyo R888, 275/35/18 (Less then 25 miles on them) - $1120.00
Rays Engineering Volk TE37 18X9.5 +22 offset - $2900.00
Engine:
ACT Race clutch - $650.00
ACT Light Weight Flywheel- $270.00
Sea Trab Oil Cooler #640 (custom brackets) – $390.00
Stainless steel lines, and AN fittings - $110.00
Perma Cool Power Steering Cooler (custom brackets and relocated) -$34.99
Greddy Oil Sand which plate adaptor - $62.00
PWR Radiator 1 of 1 ever made - $599.99
Road Race Engineering 3" Cat back Exhaust - $520.00
Road Race Engineering Stainless Steel 3” Test Pipe - $120.00
ETS Downpipe /O2 housing - $440.00
Forced Performance FP Red Turbo , Ported - $1494.00
Forge Motor Sports Waste gate Actuator - $194.00
ETS Lower Intercooler Pipe (black) - $240.00
Road Race Engineering Upper Intercooler pipe (custom, black) $220.00
ETS 4” Intercooler - $699.00
Road Race Engineering Intake (custom, black) - $200.00
Synapse Synchronic Blow Off Valve -$196.00
Cosworth MX1 Camshafts - $712.00
RC Engineering 1000CC Injectors - $340.00
AMS Performance Fuel Rail - $239.00
Walbro Fuel Pump - $95.00
Road Race Engineering Custom Catch Can - $120.00
Here are SOME pics of the car. Serious buyers... Email me.
Current Wing on the car (Dirty in the 1st pic) Sorry:
Steering Wheel:
Dash/Gauge Setup:
Side Shot (old wing)
Front Corner shot (old wing)
Rims/Tires/Brakes:
Here is a general idea of what the interior looks like:
I don't frequent this board much, so the best method of contact, is Email
Email: superiorsounddesigns@yahoo.com
No test drives, unless you got a decent sized deposit.
Price is set at $44,000.00 Pretty Damn Firm.
I am up for trades + cash... but only interested in Authentic RHD DC2's or EK's
Thanks for looking,
-Chris
Old Aug 22, 2009 | 01:41 PM
EcHoB18C1's Avatar
Default Re: FS: 2008 Lancer Evolution X Track/Show - Not a DD. Anaheim
thats a beast
Old Aug 22, 2009 | 01:49 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Bump for viewing.
Old Aug 22, 2009 | 03:43 PM
dc_TypeR's Avatar
Yes sir, it is a beast.... and not even at its full potential yet
Thanks for the bumps guys!
I wanna get this thing sold.
It is listed on Ebay, Autotrader, craigslist, socalevo.net, and evolutionm.net.
If you guys frequent any other boards... please feel free to copy and paste my add.
The more networking I can do, the better chance of it getting sold.
Also... I will give the person who sends me a referral (that buys the car) $1000.00 CASH.
Thanks again guys,
Chris
Old Aug 22, 2009 | 03:52 PM
eg2jr's Avatar
bump i want an evo...someday
Old Aug 22, 2009 | 03:57 PM
egluv92's Avatar
Old Aug 22, 2009 | 03:59 PM
beaneg6's Avatar
road race is down the street from me! they do good ****!
Old Aug 24, 2009 | 09:12 PM
dc_TypeR's Avatar
beaneg6... they do great work over there!
I've trusted them with my car since day 1... never had 1 problem, on anything!
Thanks guys for the bumps!
-Chris
Old Aug 24, 2009 | 09:32 PM
Sixfortyfive's Avatar
Thanks again guys,
Chris[/QUOTE]
someone take advantage
Old Aug 24, 2009 | 09:39 PM
monkey_boi's Avatar
WOOO
YOU SAID A G FOR A REFFERAL ???
damn to much carbon for me but fukk its nice
Old Aug 24, 2009 | 10:39 PM
geek2droo's Avatar
woah woah.
Old Aug 24, 2009 | 10:42 PM
civic nation's Avatar
avatar all wrong man
Old Aug 27, 2009 | 10:21 PM
dc_TypeR's Avatar
Bump.
Price drop. $42k.
I need it gone.
Old Aug 27, 2009 | 11:39 PM
dohcem1's Avatar
bump. nice ride
Old Aug 27, 2009 | 11:46 PM
juston's Avatar
let me test drive it. see if it runs find :D
Old Aug 28, 2009 | 12:19 AM
Cras-Delsol's Avatar
x2
Old Aug 29, 2009 | 11:34 AM
dc_TypeR's Avatar
Stock weight: 3545 lbs
Weight Reduction: - 586 lbs
Roll Cage Weight: + 180 lbs
Total weight wet: 3139
Old Aug 29, 2009 | 11:40 AM
EKGZER's Avatar
Bump for a EFFIN BEAST!
Old Aug 29, 2009 | 12:46 PM
EeF's Avatar
EeF
bump for a sick evo
Old Sep 3, 2009 | 03:31 PM
dc_TypeR's Avatar
Thanks guys ^^
TTT
I want her gone!
-Chris
killerpenguin21
Jun 4, 2017 06:46 PM
dc_TypeR
Sep 3, 2009 03:30 PM
PhantomSTi
Feb 24, 2009 08:15 AM
nfn15037
Oct 13, 2006 07:33 AM
bb6h22a
14
Oct 11, 2002 07:20 AM
