My car won't start after it was stolen
Some bastard stole my car the other day. After they recovered it, I found that it won't start.
I have a 90 civic lx sedan with those motorized seatbelts. The guy that stole the car ripped the fuse cover off the battery, but it doesn't appear that he cut any wires. Now when I turn the key all I hear is a click coming from under the dash, no starter engagement at all.
Anyone have any ideas what might have happened? Could something have shorted out? I checked all the fuses related to the car starting and they all seemed fine. Is there a simple trick theives use to make the car undriveable?
I'd appreciate any ideas you guys might have.
Thanks
Mike
Thanks
Mike
I was stolen at 11:30 Saturday and recovered at around 1 that afternoon. So I don't think the battery would go dead that quick. Plus all the accessories still work
Mike
Mike
put a voltmeter and ammeter(clip on starter tester style) on the battery cable and turn it over. Then tell us the readings.
-Dustin
-Dustin
Sorry, I don't quite understand what you're saying. I have a voltmeter, but I'm not quite sure how to use it, except to check voltage across a battery. I checked the battery and it read right at 12 volts.
Are you saying hook one end up to the battery and one to the starter?
Mike
Mike
how'd he start it, hot wire? punched ignition? maybe there isnt enough power coming through the ignition wires to turn the starter
does ur engine turn at all?? if not, ya check the wiring connections to the starter...
or try getting a new start motor.. when my start motor was gone, all i heard was a little click sound...no turning. so look into that..
ur accesories may still work on a weak battery.. but just in case it is a fresh battery, it could be the wiring or the start motor
AmauryR
Mar 6, 2005 11:22 PM
