head swap problem
my head on my d16y8 was warped so i swaped it out for another, i got it all back together but the car wont idle and isnt running right, i have to give it gas to keep it running and its running like almost 0 vac, only thing i can think of is the timing belt is a tooth off? need help ASAP thanks!
i thinkkk i may have got it fixed... the timing seemd to b not right but now that we got it on the right teeth the belt went loose? im trying to get a ratchet on the tensioner but its so cramped and i cant get a ratchet around it sooooo im stuck right now
what i think happend was i had the came set to tdc while the crank was set to exhaust tdc instead of the compression stroke so the valves were opeing up oposite as they should, then i fixed it but it ended up being a couple teeth off, soooo now i THINK i have it right but the belt is too loose to try to start it.... so im messing with the tensioner at the moment but its not working out too well
EF9_TryMe
Sep 30, 2012 07:39 PM
Stoich
28
Jul 5, 2005 09:29 PM
