HELP!!! Swapping 2000 HX into 2000 EX!
Old Aug 21, 2009 | 05:38 PM
b18cEK's Avatar
Default HELP!!! Swapping 2000 HX into 2000 EX!
Got the whole HX swap in and there is an extra plug going to the ecu! The fuel pump is also not priming. Anyone know whats up with the extra plug. We are using the HX wiring harness and Hx ecu.
Old Aug 21, 2009 | 05:46 PM
94EG8's Avatar
Seagull Management
Default Re: HELP!!! Swapping 2000 HX into 2000 EX!
All HXs are OBD2A, all other '99 - '00 civics are OBD2B, you will need to swap the interior harness as well as the engine harness from the HX.
Old Aug 21, 2009 | 05:48 PM
b18cEK's Avatar
can I change the ex harness, ecu, intake, and exhuast manifold?
Old Aug 21, 2009 | 07:33 PM
b18cEK's Avatar
help plz
Old Aug 22, 2009 | 12:13 AM
Linked's Avatar
your gonna be using everything fromy our HX to put in your ex (if that is what you meant, i didnt understand the qs)
including harness, ecu, and idk if you need to swap your exhaust mani, if the ex bolts up to your hx then my guess is your fine
Old Aug 23, 2009 | 07:15 AM
b18cEK's Avatar
so a 99-00 interior harness is all that is needed? anyone have a write up on how to swap interior harnesses?
Old Aug 23, 2009 | 07:26 AM
JDM_SOHC's Avatar
i didnt realize HX swap was such a mission...
Old Aug 23, 2009 | 07:27 AM
b18cEK's Avatar
yea me neither. lol
1995integraGSR
Nov 20, 2014 05:21 PM
USDM-EK4*
Aug 26, 2009 04:35 PM
BigRonDawg
Apr 25, 2006 09:37 AM
BlueRex12
Oct 21, 2005 05:54 PM
