1998 (OBD2A) honda hatchback CX:d16y5 swap questions
I just picked up a '97 (obd2a) d16y5 from a scrap yard with 180psi compression all the way across, complete engine harness, ecu (hx)and trans. If I pull the old engine harness including the ecu potion inside the car, will the HX harness work on the car? Are the interior harnesses of the CX and the HX the same? The only plug of the Engine harness that will be used is the drivers side shock tower plug correct?
I just would like to make sure that installing the engine in the hatchback will work and not be a waste of time. I have the 5 wire oxygen sensor and complete intake manifold off an HX also.
I was thinking about installing a Civic VX transmission also for maximum fuel mileage and getting a scan gauge or MPG guino in the future if everything goes as planned.
Thank you in advance.
If you loved me, you'd all sell me your magic cards to me today
Re: 1998 (OBD2A) honda hatchback CX:d16y5 swap questions
Use the harness that came with the car, HX civics I think were OBD2A, you may want to research that though.
Fish Twig
HX was obd2a all the way to 2000 for 5spd, HX was obd2a from 96-98 for cvt and obd2b for 99-00 for the cvt.
If you're saying this civic you're swapping in is indeed obd2a than it should be complete plug and play.
How'd this turn out for you? Ive been curious about this type of swap for some time. I hope to hear a significant MPG increase with a D16Y5 into a 92-95 hatch.
b18cEK
08-23-2009 07:27 AM
ottobell22
04-08-2005 06:22 AM
