NEED HELP PLEASE!! DESPRITE
Old Aug 21, 2009 | 01:05 PM
icanbrkurhrt's Avatar
Default NEED HELP PLEASE!! DESPRITE
ok i have a 1990 ef sedan 1.5L stock motor with 214,XXX miles. i bought the car a few months ago. it ran really well when i first bought it. about 2 months ago little things here and there started needing some tlc. this is what i've replaced...
NEW:
starter
radiator
head gasket
axels
battery
TUNE UP:
spark plugs and wires
cap and rotor
and i also got my valves adjusted. just picked up the car yesterday from getting the head gasket replaced and the radiator installed. when i picked it up it started right up and drove great. took it home and didnt drive it the rest of the day. this morning i tried starting it again and it wouldnt start. it cranks over but wont start. SOB! im almost ready to roll the car off a cliff. i've spent about $1400 on the car within the past 2 months. i dont know what else it could be. can anyone help me out and throw out some suggestions please save me here. thanks in advance.
Old Aug 21, 2009 | 01:21 PM
BiG ChOr!Zo's Avatar
Default Re: need help please
look for any CEL and change main relay...!!!
Old Aug 21, 2009 | 01:50 PM
ryanevansoh's Avatar
do you here the fuel pump priming when you turn the car to the on position? if not replace main relay
Old Aug 21, 2009 | 03:34 PM
shawn_crx's Avatar
bad timing setting?
Old Aug 21, 2009 | 04:54 PM
i was thinking maybe the timing so im gonna have a friend check that out.
i'll check the main relay too. thanks for the input guys. any other suggestions would be great too.
Old Aug 21, 2009 | 05:31 PM
ok so i cant check the timing because they car has to be on right?
well i wont turn on. im starting to think its not the main relay because from what i heard it has to do with temperature. my car wont turn on when its cold or hot. so does that still mean the main relay could be bad?
Old Aug 21, 2009 | 05:35 PM
dacrxguy's Avatar
Ther are referring to the cam being timed with the crankshaft that is referred to mechanical timing ignition timing is the timing thta is checked with a timing gun check you mechanical timming
Old Aug 21, 2009 | 05:36 PM
dacrxguy's Avatar
ps who did the work for you
Old Aug 21, 2009 | 10:02 PM
frank_el_tanke's Avatar
Default Re: NEED HELP PLEASE!! DESPRITE
you can check to see if the timing belt is on correctly. just remove the timing belt cover and line up the mark on the crank shaft pulley, then see if your cylinder number 1 is at tdc.
if you do not hear your fuel pump prime when you turn the key to "on" position then your main relay needs to be replaced.
timothywhitt
Jul 14, 2012 06:40 AM
h22silvia
Jul 28, 2009 09:53 PM
hurricanenamedditka
May 25, 2005 06:51 AM
hurricanenamedditka
May 24, 2005 05:11 AM
fluffy
18
Nov 8, 2002 05:10 AM
