measuring tps voltage
Old Aug 26, 2002 | 01:59 AM
_Endless_'s Avatar
Default measuring tps voltage
where should i put the probes while measuring tps voltage, i tried to probe the socket where the 3 wires came out but i think it's sealed. i tried unplugging the socket but i couldn't see the leads of the tps. you know how they position the tps. how did you guys do it?
Old Aug 26, 2002 | 07:13 AM
Mikey3000's Avatar
Default Re: measuring tps voltage (_Endless_)
you gotta get long skinny probes to stick up the back side of the plug (where the wires go into the plug).
Old Aug 26, 2002 | 08:41 AM
EE_Chris's Avatar
Default Re: measuring tps voltage (Salvatore Leone)
Or you could get a set of these:
Its from The Tool Warehouse.
Old Aug 26, 2002 | 01:24 PM
Perfectionist's Avatar
Just use a couple of shirt pins (needles) and push them into the connectors. The tricky part is knowing when they're in far enough and making a good connetion. BTW, for the TPS, you only need to tap the center wire. Use the chassis ground for the other connection.
Old Aug 26, 2002 | 04:42 PM
slooowDX's Avatar
Default Re: measuring tps voltage (Perfectionist)
i think it should read about 0.5 Volts closed and 4.5 Volts fully opened, you could also try paper clips, that worked for me
Old Aug 26, 2002 | 05:55 PM
_Endless_'s Avatar
Default Re: measuring tps voltage (slooowDX)
ok. thanks guys.
Chugger
Jan 21, 2007 06:21 AM
iphatcrxi
Oct 5, 2006 08:49 AM
HickamHatch
Aug 26, 2006 08:21 PM
ZzZCivicZzZ
Aug 11, 2006 11:58 PM
drjondurst
21
Apr 9, 2003 08:37 PM
