Headgasket for b16a2
Old Aug 20, 2009 | 04:41 PM
jkalex05's Avatar
Default Headgasket for b16a2
What is my best, should I get an OEM headgasket or an aftermarket. If aftermarket what should I get.
Mine has a small leak and im getting it replaced tomarrow.
Just need some input.
Old Aug 20, 2009 | 04:55 PM
98civdx's Avatar
Master Detailer
Default Re: Headgasket for b16a2
is the motor stock?
If it were me id go oem.
Old Aug 20, 2009 | 05:18 PM
tuck1crx's Avatar
^^ i second that
Old Aug 20, 2009 | 05:25 PM
jkalex05's Avatar
Its not stock, it has some bolt ons. Im gonna go with a Cometic MLS Headgasket, its stronger than oem and just like 20 bucks more expensive.
Old Aug 20, 2009 | 05:37 PM
RiverRat2's Avatar
Sounds like youi have it figured out!!!!!
Old Aug 20, 2009 | 05:40 PM
Gunmetal_B20_Hatch's Avatar
lol... 2 people suggest OEM, and he goes and gets a Cometic... Go figure.
+1 for H-T
Old Aug 20, 2009 | 05:55 PM
jkalex05's Avatar
Bro I have alot of buddies that recommend to go comitec. Im going to be lowering the compression of the motor to 9:1 and adding a Precision 6262 Turbo build on it, custom built kit in the next couple of months so I need a stronger gasket.
Old Aug 20, 2009 | 09:02 PM
jkalex05's Avatar
After doing some reserach. I find out that comitec HG sucks! So im going with OEM Honda.
Old Aug 20, 2009 | 09:07 PM
EL Vap133's Avatar
OEM is good unless you got major plans for the car.
Jimster480's Avatar
you can get a cometic one that creates lower compression. if you want to keep it the same just get a Fel-Pro Gasket. Thats what I use and its a built and boosted motor. Hasnt failed on me. I few other people I know use Fel-Pro also and no problems with any of them.
Old Aug 20, 2009 | 10:23 PM
98civdx's Avatar
Master Detailer
alot of people have problems with comitec head gaskets and some dont.
oem is great, but is only good to a certain point
Old Aug 21, 2009 | 02:14 AM
crxboy909's Avatar
i recently did my hg with a fel-pro hg and it falied on me =[ i must not be doing it right then huh lol....
Old Aug 21, 2009 | 07:29 AM
Jimster480's Avatar
duno sometimes it just depends on how u TQ it down. but ive had 2 of them and they are fine and the one on my friends car is still going good.
IBriaIN
Jan 7, 2011 12:22 AM
boostedteg4dr
Nov 19, 2008 12:41 PM
Krucial_Ek9
Jul 23, 2007 05:48 PM
SpoolnG2
Oct 28, 2003 07:30 PM
