Mass Air sensor?
Yesterday I cleaned my engine bay out w/engine degreaser and tire foam mix. I let the solution set for 10-15 mins and then washed off the entire engine bay, while the car was off. I should have kept her running the whole time
Today when I'm driving the R when I attempt to accelerate the engine struggles to reach higher RPM's as if it's lost power, I.E. the pedal surges/feels bumpy. I'm thinking that I may have got my mass air sensor wet. On top of all this the check engine light flashes, @ one point 26 times. I've had no problems before hand. I'm a bit confused as to what the problem could be
I will take it to Autozone so they can chekc to see if its my sensor, that or honda/acura. Thanks for your help in advanced
Car has 88k on the dash, all maintenance has been done up to this put. I.E. regular oil changes every 2500-3000 miles. Trans drain & refill, etc.
I will take it to Autozone so they can chekc to see if its my sensor, that or honda/acura. Thanks for your help in advancedCar has 88k on the dash, all maintenance has been done up to this put. I.E. regular oil changes every 2500-3000 miles. Trans drain & refill, etc.
you are grounding out your spark
check to see if there is water around the spark plugs or if water got inside your distributor
You can either dry it off with an air hose or a can of compressed air or just let the car idle and let it evaporate. No biggie
Yeah that's right I remeber there being lil pockets of water round the spark plugs yesterday once I took the spark plug cover off. Ok I'll buy some compressed air on my way hm today. Yeah I just realized that no, Mass Air sensor. Thanks
mujjackson
Honda Civic (2001 - 2005)
Dec 13, 2013 04:22 PM
