reving up and down at idle
Old Aug 19, 2009 | 06:01 PM
mikester1222's Avatar
Default reving up and down at idle
i have a b16a1 sawp in my 89 crx and it is reving up and down at idle but i can not figure out what it is what could be causing it. i have heard is the iacv in that case is there any other motor i can take that from cuz the cheapest ones i have found is 200 bucks anyone want to sell one for 50?
Old Aug 19, 2009 | 06:09 PM
k20aed6's Avatar
Default Re: reving up and down at idle
u do not need a new iacv, all u have to do is unbolt it from tha mani an clean tha whole surface area an tha lil screen thats n there...iv heard ta use card carb cleaner but mi EF was doin that an i jus used water an it fixed mi idle perfectli
Old Aug 19, 2009 | 06:14 PM
i actually already tried that and still its was messed up i will try it again though. i used carb cleaner to do it.
Old Aug 19, 2009 | 06:19 PM
~sp33~'s Avatar
EFB055
There's also a FITV that bolts underneath the throttle body, you can try cleaning that. If that doesn't do anything try searching for vacuum leaks.
Old Aug 19, 2009 | 08:09 PM
ugpcrx's Avatar
whats a fitv??
Old Aug 19, 2009 | 08:13 PM
Fo-Do Fanatic's Avatar
Originally Posted by ugpcrx
whats a fitv??
FITV is short for fast idle thermo valve.
Heres a thread on how to clean it:
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/
Old Aug 19, 2009 | 10:13 PM
sh!ft's Avatar
Who the fack changed my title?!
IACV IACV IACV!!!
Old Aug 19, 2009 | 10:27 PM
~sp33~'s Avatar
EFB055
Originally Posted by sh!ft
IACV IACV IACV!!!
? Did you read the thread?
Old Aug 20, 2009 | 01:17 AM
Idiots lol.
Thread Jack: SP33, I still wanna buy your 4wd4do!! PM me I have a question for you.
OP: Check your FITV like sp33 and I said, I'm almost positive that is the problem. If the FITV goes bad it will stay open when the motor is at optimum temperture when it's supposed to close at that point and cause a major vacuume leak. Some people clean it and that may help the problem, but IMO I'd just buy a new one and replace it so you know that part is good.
Old Aug 20, 2009 | 03:08 PM
thanks everyone i think i got if figured out it was the fitv that was causing it. thanks guys for all the help.
wildoutwhitegsr
Sep 13, 2017 05:57 PM
LuckyJDM
Nov 20, 2013 08:39 PM
averyvm
17
Jan 17, 2007 11:51 AM
4ghatch
Sep 28, 2005 02:59 AM
94SHOWLS
Feb 17, 2005 12:31 PM
