do you need your ac bracket?
I have a 96 civic coupe with b18c turbo. I took all the ac parts out of my car. except the ac braket thing that looks like it mounts under my driver side motor mount. My question is do i need this still bolted on? is it holding any weight of the motor?
you don't need the tensioner from the piece, but it is an engine mount. I would use it. you might be able to find one with out A/C but its not worth the time.
^^ thanks i figured it was an engine mount because it bolts to the frame under the driver side wheel well but just wasnt sure because i thought i have seen cars without this. maybe i was mistaken?
Get a Type R one, its cast aluminum, which is much lighter and prettier...
with stock motor mounts i'd recommend using it. if you have some nice solid mounts you may not need it, though.
prison_snitch
Jun 9, 2006 01:32 PM
Dr. Gonzo
Sep 6, 2003 11:10 AM
