I need help fixing a few things...
Old Aug 19, 2009 | 07:08 AM
EggRollEMT's Avatar
Icon6 I need help fixing a few things...
So I bought a used 1997 Honda civic lx and need some help with a few problems I've found with the car.
First, broken fuel gauge says my tank is always full...how is that fixed?
Second, how do you open a door that doesn't open from the inside OR the outside?
Old Aug 19, 2009 | 07:18 AM
flip_nl's Avatar
Default Re: I need help fixing a few things...
First thing could be 3 things, the cluster, the wiring or the sensor. Check those 3.
Check the service manual for more detail: http://www.spoonertuner.com/manuals
2nd: there are tools available that you can stick through your window moldings and pull the leverage with. Kinda like fishing lol. I have no idea what its called in the US however.
Old Aug 19, 2009 | 08:06 AM
thumper64's Avatar
That tool you stick in the window is for popping the lock, not the latch.
Old Aug 19, 2009 | 08:24 AM
Former User's Avatar
I'll be interested to hear what the solution is for the door problem.
For fuel gauge problem:
1) Remove cluster
2) Unplug only cluster connector B
3) Turn ignition switch to ON(II) to see whether gas gauge needle drops. If needle does not drop, then the cluster or gauge is bad. If it drops, then I'll post additional information for troubleshooting the sending unit circuit.
Old Aug 20, 2009 | 08:04 AM
EggRollEMT's Avatar
ok so i removed the cluster and the needle didn't move...now what?
Old Aug 20, 2009 | 08:13 AM
Just for clarification, did you follow the step by step procedure in my previous post? Because if you simply completely removed the cluster, then the test did not yield any useful information.
Old Aug 20, 2009 | 08:35 AM
EggRollEMT's Avatar
yes i removed the cluster and then turned the car to the on position and the needle did not move
Old Aug 20, 2009 | 09:22 AM
Again, just to clarify, you only unplugged connector B for the test, right? If so, the cluster or gauge is bad.
Old Aug 20, 2009 | 09:38 AM
EggRollEMT's Avatar
correct...i unplugged ONLY cluster B, the one on the top, and turned the car into the on position with no movement at all.
Old Aug 20, 2009 | 09:48 AM
Okay, you might want to look into a new cluster. It may or may not be aproblem with the gauge itself.
Old Aug 20, 2009 | 10:02 AM
shak3yb0n3z's Avatar
if your door doesn't open from the inside or out, take the panel off and reach in and pull the lever yourself. or find a door diagram and slimjim it open.
Old Aug 20, 2009 | 10:11 AM
How do you remove the panel with the door closed?
Old Aug 20, 2009 | 10:17 AM
EggRollEMT's Avatar
So how do I got about replacing the cluster then? And as far as with the door I can't open it which means I can't take the side panel off
Old Aug 20, 2009 | 10:19 AM
Buy a new or used cluster.
Oh, my bad, didn't know the door would open. Definitely remove the panel. That's the road to the fix.
sde780's Avatar
1. Take out cluster
2. Put in new cluster
Jk
I guess you can pop the door panel off with the door closed, but it'll have to bend a bit
Old Aug 20, 2009 | 10:20 AM
Originally Posted by sde780
1. Take out cluster
Such complicated instructions.
Old Aug 20, 2009 | 11:24 AM
EggRollEMT's Avatar
And if it's the gauge assembly do I just have to get one of those from a Honda dealership? I'm just starting to get into the whole fixing cars up thing so sorry for all the noob questions...
Old Aug 20, 2009 | 05:35 PM
sde780's Avatar
Buy it used, much much cheaper
zxpher1
Aug 25, 2009 06:30 PM
bokals
May 15, 2006 07:11 PM
NsX_CrX
May 30, 2005 04:55 PM
vmm
Apr 18, 2005 04:05 PM
