The best way to build my LS CRX(All Motor)
Old Aug 18, 2009 | 10:16 PM
enigma2446's Avatar
Default The best way to build my LS CRX(All Motor)
im about to swap my d15b for a b18a1 its preety quick as is with full exhoust and intake in my old DA so it must be quick in my Crx right!!!!!.....any tips on buliding the engine up it has stock internals so something got to give
Old Aug 18, 2009 | 10:24 PM
0ne-Cam's Avatar
Default Re: The best way to build my LS CRX(All Motor)
tear it all down and invest about 5k in the engine bay area and you will be fine.
Old Aug 18, 2009 | 10:39 PM
D16SiHatch's Avatar
if it was in good running shape i wouldn't mess with it any more than replacing some seals. if you're just planning to mash on it every now and again and never do anything major like boost it, then theres no reason to go all out. now if your goal is just to have a fresh engine then by all means tear er down and replace rings, rod/main bearings, etc.
Old Aug 19, 2009 | 02:27 AM
.Manny.'s Avatar
Touching My Member
what exactly do you want to do? and most importantly...how much money do you have to spend?
Old Aug 19, 2009 | 05:44 AM
BLU CIVIC's Avatar
Track Advocate
there you go
https://honda-tech.com/forums/showth...iable+b20+vtec
D16ekhatch
May 19, 2013 03:30 PM
DA john
Aug 31, 2010 06:00 AM
shawty123
Apr 30, 2007 01:44 AM
im honda matt
Mar 8, 2005 07:35 AM
gumbybum
Apr 23, 2003 10:50 AM
