Wiring switch to turn fuel pump or starter on to protect from thieves..???
Old Aug 25, 2002 | 08:38 PM
IdotheSHOCKER's Avatar
Default Wiring switch to turn fuel pump or starter on to protect from thieves..???
Well I understand how it will work but does anyone have any good information or sites that show the best way to do this??
Thanks.
Old Aug 25, 2002 | 08:52 PM
BrandonClaps's Avatar
New User
Default Re: Wiring switch to turn fuel pump or starter on to protect from thieves..??? (EGB18hatch)
http://forums.clubsi.com/showflat.ph...sb=5&o=0&fpart=
Old Aug 25, 2002 | 08:54 PM
Default Re: Wiring switch to turn fuel pump or starter on to protect from thieves..??? (BrandonClaps)
Thanks man, own you one !!
Old Aug 25, 2002 | 08:55 PM
New User
mhmm ;]
Old Aug 25, 2002 | 11:48 PM
deviant1's Avatar
does anything bad happen to the engine if someone tries to turn it on for a long time with the fuel not going into the engine because of the switch?
Old Aug 26, 2002 | 12:08 AM
97hb's Avatar
Default Re: Wiring switch to turn fuel pump or starter on to protect from thieves..??? (deviant1)
Thats how the manual says to relieve the fuel pressure.
Old Aug 26, 2002 | 12:10 AM
Kamin's Avatar
it can kill your battery
but no
it only does a few rpm (litterally less than 75 rpm)
so its not gonna hurt anything.
Old Sep 4, 2002 | 06:03 PM
deviant1's Avatar
Default Re: Wiring switch to turn fuel pump or starter on to protect from thieves..??? (KAMiN)
what gauge wire and what amperage switch is recommended? any special switch? is there a need for a fuse? if yes, where would you hook it up and how? thanks all!
Old Sep 4, 2002 | 08:43 PM
deviant1's Avatar
bump
Old Sep 4, 2002 | 09:12 PM
s.khang's Avatar
http://jdmfan.com/technical/audio-security/killswitch/
Old Sep 4, 2002 | 09:50 PM
underrated99si's Avatar
Default Re: Wiring switch to turn fuel pump or starter on to protect from thieves..??? (red92hatch)
realy you dont even take out the cover on the full pump just take off back seat and find the fuel pump wire and cut it and put toggle swith in between and extend the wire and mount in any wherr in the car cost about 3 dollars to do
Old Sep 4, 2002 | 09:53 PM
deviant1's Avatar
Default Re: Wiring switch to turn fuel pump or starter on to protect from thieves..??? (underrated99si)
ok then. what amperage switch? any special switch required? just any old switch will do? does it need a fuse? what gauge wire should you use?
Old Sep 4, 2002 | 09:58 PM
speshuled619's Avatar
can i use the info from this link to do the pump and starter? can it both be done this same way?
WildChild
Audio / Security / Video
Sep 7, 2005 08:29 AM
Mgsr
Jun 24, 2005 10:51 AM
erikiksaz1
15
Mar 29, 2005 03:41 PM
kKdARIAN
16
Dec 16, 2002 09:06 AM
