00 v6 Loose ALL Power Randomly
Old Aug 18, 2009 | 11:55 AM
Nbboy7's Avatar
Default 00 v6 Loose ALL Power Randomly
Short story. I can be driving the car and it will loose all power and engine dies. No window,radio clock Etc will work. When i try to start it everything is dime and barley have any power.But if it sits there for 30mins it will start and drive like normal. I would need to put the code for the radio again. I checked all grounds they look good so are the battery terminals. Battery and alternator are good. Any kind of help will be greatly appreciated.
Old Aug 18, 2009 | 10:00 PM
CG6Accord8o1's Avatar
Default Re: 00 v6 Loose ALL Power Randomly
u need a tune up? mutiplexor? starter?
Old Aug 18, 2009 | 10:18 PM
civicsir924's Avatar
Sounds like ignition switch or main relay problem.
Old Aug 19, 2009 | 01:19 AM
YeuEmMaiMai's Avatar
wasn't there a recall for those switches? why yes there was. register the car with owner's link and it will show you the status of any recalls
Old Aug 21, 2009 | 06:55 AM
spingley's Avatar
New User
I have a 99 Accord with the same problem, can you explain how to register car with owners link? For some reason I can't figure out how to do it and am new to site.
Old Aug 21, 2009 | 07:25 AM
brages's Avatar
Even if the recall has been performed in the past, your ignition switch could still be bad. It Happened To Me - at 175,000 miles.
Old Aug 21, 2009 | 03:47 PM
gomez23baller's Avatar
New User
Post Re: 00 v6 Loose ALL Power Randomly
I have a 98 accord I had the same problem. I could be driving and it would just shut off. Its your main relay switch. Mine has been running perfect since
Old Aug 22, 2009 | 05:30 AM
spingley's Avatar
New User
The ignition switch was replaced on my 99 on recall, I think maybe I may be having a problem with the main relay also, can anyone give me a clue as to where it is located?
Old Aug 22, 2009 | 02:17 PM
New User
the main relay is located underneath the steering wheel when you put your key in the ignition you will here the beeping follow the beeping and that is your main relay
Old Aug 23, 2009 | 04:43 AM
spingley's Avatar
New User
Found it. Thanks!!!
CRXguy_88
Feb 22, 2012 07:49 PM
LS1SSM6
Aug 25, 2011 05:51 AM
dnguy47
May 8, 2010 05:53 PM
CTR LOVER LU
14
Mar 23, 2010 08:36 PM
JayJay99
19
Apr 11, 2009 04:43 AM
