which lug nuts to used for weld draglites?
Old Aug 18, 2009 | 10:51 AM
2.0_civic's Avatar
Default which lug nuts to used for weld draglites?
hello H-T,Im new here and i have a question to ask ya.
Recently i have bought a set of used 13x8 weld draglites drag racing wheels and it didnt come with any lug nuts.So my question is which style lug nuts should i used?and where could i buy them?
Old Aug 18, 2009 | 11:17 AM
redboost10's Avatar
Default Re: which lug nuts to used for weld draglites?
i use the acorn style ones on my welds, but be sure to use those little gold inserts that have the concave surface.
Old Aug 18, 2009 | 11:18 AM
dpetro1's Avatar
pretty sure most weld wheels use shank style lugs. is there a part number we could cross reference, didnt know they had a 13". the standard lug specs are:
Lug Nut Seat Style: Shank
Lug Nut Shank Length (in): 1.300-1.380 in.
Lug Nut Shank Diameter (in): 0.679-0.687 in.
Washer Outside Diameter (in): 1.250 in.
i think the import magnums are dual drilled for either short shank or conical lugs.
Old Aug 18, 2009 | 11:20 AM
jdm inc's Avatar
I believe those require a shank style lug nut
you can purchase some from summit racing
http://www.summitracing.com/parts/SUM-7540061/
Old Aug 18, 2009 | 11:44 AM
dpetro1's Avatar
i dont think those are long enough, as stated above i think you need the 1.3-1.38 length
so these
http://www.summitracing.com/parts/SUM-7540141/
or the actual weld brand (matches the suggested lug in their catalog)
http://www.summitracing.com/parts/WLD-601-1412/
Old Aug 18, 2009 | 12:23 PM
jdm inc's Avatar
^^ yea there you go Thanks. I used those ones for my weld magnums. I guess the draglites need a little longer one.
Old Aug 18, 2009 | 10:46 PM
2.0_civic's Avatar
wow thanks you guys,this info just helped me alot.
VMS_Racing
Sep 20, 2016 12:39 PM
corvair
Nov 2, 2009 04:15 AM
Lithel
Oct 6, 2008 11:47 AM
