A Quick Design
Old Aug 17, 2009 | 03:11 PM
corrupt0r's Avatar
Default A Quick Design
A previous owner put an intake on my car and it wore through the AC line due to not being properly fixed into place. Well I want to fix my AC so I made a quick bracket using Google SketchUp which I will either cut out by hand or have my work water jet it.
I'll post pics of the final piece as well when I get it done. Any ideas on what thickness would be sufficient to support the few pounds of force and vibration this will cause?
Old Aug 17, 2009 | 04:56 PM
k24em2's Avatar
Default Re: A Quick Design
some 16 gauges from home depot should work fine...just put some rubber around the inside of the hole
Old Aug 17, 2009 | 09:12 PM
Top Ramen's Avatar
If you can't find a grommet the right size, just slit a vacuum hose length-wise, cut it to just a bit longer than the circumference and press it on. If it doesn't want to stay, use a small bead of weather strip adhesive.
Best of luck with your project.
Old Aug 18, 2009 | 09:05 AM
corrupt0r's Avatar
Yeah, I was definitely planning on doing some type of padding between the tube and bracket. Well I can't get it water jetted, so I guess I am gonna be getting to know my pair of tin snips very well tonight.
Old Aug 18, 2009 | 09:57 AM
EchaKqulo's Avatar
You should avoid sharp edges, special at the inside, they are stress concentration areas. This bracket will not may received a lot of force, but the little force it will receive will be converted into fatigue and that fatigue could cause your bracket to fail/crack starting on the inside sharp edges. you might want to use a min. radius of .125" on those sharp edges.
Good job though!!!
JKov240
Apr 12, 2011 08:23 PM
turbojeesx
Welding / Fabrication
Jul 17, 2009 05:36 AM
traxxasx
Mar 1, 2009 07:31 PM
AlphaKennyWun
Jan 23, 2002 05:24 PM
Kendrick07
Jun 19, 2001 12:25 PM
