afr's rich tuned in winter now summer. how much power loss?
Old Aug 17, 2009 | 04:42 AM
J$taboostlover's Avatar
New User
Default afr's rich tuned in winter now summer. how much power loss?
Like the title said i had my car tuned last winter (50 degree weather) and now the car is running rich in 80 degree weather which is normal. Car made 375 hp at 15 lbs's and afr's were in the mid 11's now the afr's are in the mid 10's. just wondering how much power im loosing by not retuning. on cooler days its fine but the warmer ones it a little rich. car doesnt smoke and plugs still look fine. just looking for a little feedback on what kind of power im loosing!
thanks
New User
Default Re: afr's rich tuned in winter now summer. how much power loss?
sorry car made 375 hp.
Old Aug 17, 2009 | 05:44 AM
blackeg's Avatar
your loosing a few hp nothing crazy. its hard to say maybe 10 or 15? once you really start to dip deep into the 10s is when you can notice some power loss
Old Aug 17, 2009 | 06:36 AM
New User
it was in the 10.30 range then climbs up a little...is that deep in the low 10's to you? are you thinking 25hp?
Old Aug 17, 2009 | 06:39 AM
Bseriescivic5's Avatar
Id be cautious about washing the cyl. walls with too much fuel. bad on bearings and so forth. You should be ok, but just my .02
Old Aug 17, 2009 | 08:03 AM
non-VTEC's Avatar
afr's in the 10's is not a good thing. you should have it tuned properly.
high 11:1 to low 12:1 afr is perfectly safe at that power level.
Old Aug 17, 2009 | 08:14 AM
New User
it holds mid/upper 11's when its cold out but in 80-90 degree weather is mid 10's doesnt smoke it is tuned correct but just in cooler weather
Old Aug 18, 2009 | 05:27 AM
New User
Old Aug 18, 2009 | 05:57 AM
non-VTEC's Avatar
you can have it re-tuned to compensate for the change in air temps. or just leave it alone....you will loose a bit of power running that much richer but you may not even feel the diffrence. 375hp at 11.5:1afr you might be seeing 350hp at 10.5:1afr....but that might just be a rough estimate other factors will also come into play..
Old Aug 18, 2009 | 08:18 AM
96 GSR-T's Avatar
most factory turbo cars run AFR's in the 10's.......
your tuner should have the capability to properly tune the air temp compensations so this issue doesnt happen.
Old Aug 18, 2009 | 10:11 AM
sleepencivic's Avatar
i didnt know that thanks for the info. is that all turbo cars or just the ones that you have worked on?
Old Aug 18, 2009 | 10:56 AM
96 GSR-T's Avatar
Only the cars worth mentioning
They do it to keep the cars reliable, alot more can go wrong IMO with a boosted engine vs a NA engine..... for a company to warranty their cars they need a good amount of failsafe built into them.
Old Aug 19, 2009 | 04:35 AM
nice
Old Aug 29, 2010 | 09:32 PM
ls_vtec_da's Avatar
in the summer the intake air temperature gets way hotter any car in the warmer weather is going to run slower but a little bit richer is ok because it helps cool the engine better.
Old Aug 30, 2010 | 07:57 AM
E85B18's Avatar
If you have a wideband why don't you just take a little fuel out yourself? No need to spend money on a re-tune
Old Aug 30, 2010 | 08:27 AM
ls_vtec_da's Avatar
not everyone has an ostrich or a chip burner
Old Aug 30, 2010 | 08:33 AM
E85B18's Avatar
I didnt see which ems he's using... I just assumed an s300
Old Aug 30, 2010 | 08:39 AM
ls_vtec_da's Avatar
i assumed an ostrich because lots of people use that
Old Aug 30, 2010 | 10:17 AM
MadVTI's Avatar
My car also does this, I need to check IAT compensation out and maybe adjust a bit. Im hoping this will help me.
Cheebo
Aug 17, 2010 06:45 PM
Gator0302
Honda Civic (2006 - 2015)
May 5, 2010 09:26 PM
IpatXcoreI
Jan 18, 2005 06:53 PM
paz
Audio / Security / Video
Aug 20, 2003 11:10 AM
