I Have a Rare Oiling Problem
Old Aug 16, 2009 | 07:10 PM
Hot Rail Tom's Avatar
New User
Default I Have a Rare Oiling Problem
I have a 2006 3.5L single port with pauter rods, JE pistons, RC injectors, Motec ECU, Intercooled turbocharged in an off-road sandrail. I just freshly rebuilt the motor and am experiencing a problem with the V-TEC trying to engage at idle when motor is cold, only. I've tried unplugging the V-TEC solenoid and installed a new solenoid. When the engine warms up the problem goes away. Anybody have any ideas on how to fix this?
Thank you,
Tom
Old Aug 16, 2009 | 08:01 PM
Garage 808 Hatch's Avatar
Default Re: I Have a Rare Oiling Problem
so, does it still do it when the solenoid is unplugged?
Old Aug 16, 2009 | 08:10 PM
riceburner700's Avatar
is the ecu modified at all? if not the ecu probably isnt letting you engage vtec until its at a certain temp for the safety of the engine
Old Aug 17, 2009 | 04:47 AM
JDogg's Avatar
he said he has motec on it..
what does it do with the vtec solenoid unpluged?
when the engine is cold it probably has enough pressure to engage vtec, then as it warms up the pressure drops. you need around 30psi for vtec to work most of the time.
try suppling a constant 12 volts to the solenoid, maybe vtec is backwards on those motors, kind of like the r18's in the new civics
Old Aug 18, 2009 | 05:05 PM
New User
Sorry guys my first post might have been a little confusing after reading some of your replies. The problem is that the V-TEC is always trying to engage, whether it's hot or cold and whether or not the solenoid is plugged in. It also can't be the ECU because i've tried unplugging all of the V-TEC wires and it still tries to engage. Somehow there is oil bleeding into the V-TEC system and I can't figure out why.
Thanks,
Tom
Old Aug 18, 2009 | 05:12 PM
00Red_SiR's Avatar
All Motor Mentor
How are you able to determine that the VTEC is "always trying to engage"? Also what exactly do you mean by "there is oil bleeding into the V-TEC system"?
Old Aug 18, 2009 | 05:56 PM
PyroProblem's Avatar
How is your oil pressure?
So there is def no vtec solenoid engagament. And it goes away when the engine warms up...
Perhaps a sticking vtec rocker or pin? (im not that familiar with k's)
Old Aug 18, 2009 | 07:34 PM
New User
ran it with valve covers off could see oil squirting out of vtec oil passage and rocker shaft
Old Aug 18, 2009 | 07:36 PM
New User
discovered that it does it all the time cold or hot
Old Aug 18, 2009 | 07:43 PM
NAH2B's Avatar
sounds to me like you have a bad selenoid or rather a bad valve. its allowing oil pressure through even when not activated which is causing your rockers to lock by themselves rather then by the engine management.
either that or your rocker pins are stuck for some reason.
it really cant be anything else
Kova23
Engine Management and Tuning
Oct 15, 2012 11:25 AM
scottypippen147
Nov 16, 2010 03:35 PM
vaporboy12
Nov 18, 2004 07:12 PM
1ntensiveVTECivic
Nov 22, 2003 10:33 PM
b19coupe
Sep 3, 2003 07:02 PM
