help...fuse keeps blowing
Today my radio and clock stopped working. I found athe blown fuse under the hood and right when I put in the replacement, it blew. I tried it a second time and that one blew immediatly also. I used the same amperage fuse, so I dont know whats wrong. ANy ideas? Thanks in advance.
Take your radio out with the harrness. (if you used one) I bet the power wire is touching ground or a ground wire. If you take the plug off the radio but leave the harness still in and the short is gone it could be the radio unit. Also make sure when the radio is in place none of the wires are against a sharp edge.
