NEED HELP FAST
Old Aug 16, 2009 | 01:52 PM
baldeagle432's Avatar
Default NEED HELP FAST
ok i have a 88 civic hatch with a b18a1 obd1 swapped i pulled the engine harness out and redid the wires because whoever di them before had it all ghetto. i but it back in and now my tach doesnt work and my car wount go over like 3000K im guessin on that since my tach doesnt work. and i keep blowing the turn signal fuse something help i need to get to work tomarrow.
Old Aug 17, 2009 | 04:38 AM
Default Re: NEED HELP FAST
anyone
Old Aug 17, 2009 | 04:45 AM
dephtone's Avatar
It sounds like you have your MAP and TPS sensor switched. Make sure your MAP sensor has a Grn/white yel/red and a white wire going to it.
Also sounds like you have a short in the turn signal wires, I would start at the signal and trace it back until you find the wire.
drunknbass
May 8, 2005 12:57 AM
ItsStockOfficer
Apr 8, 2005 08:27 PM
flip1199
Dec 28, 2003 11:12 PM
xXx Justin xXx
Jun 18, 2003 09:49 AM
