Intake Breather Hose / Sensor on B16A SiRII question....
My friend's B16A has (as far as I can see) a breather hose coming out of the valve cover and also a sensor (looks kinda like an o2 sensor) going into the intake tube. He's going to be purchasing an AEM CAI soon and from my experience the breather tube goes into the AEM... but what about the extra sensor on the stock arm? Thanks in advance!
[Modified by skafia, 5:49 PM 8/25/2002]
[QUOTE]My friend's B16A has (as far as I can see) a breather hose coming out of the valve cover and also a sensor (looks kinda like an o2 sensor) going into the intake tube. He's going to be purchasing an AEM CAI soon and from my experience the breather tube goes into the AEM... but what about the extra sensor on the stock arm? Thanks in advance!QUOTE]
Depending what AEM intake he gets, it should have a hole and a rubber grommet to be able to put the IAT (Intake Air Temperature) sensor in there...
Take care,
@= SpoolinSol
Take care,
@= SpoolinSol
He's going to get the ITR CAI system and I believe that only has 1 hole for the breather... where would the "sensor" go?
when you go to install the intake, its very straight forward.....i wouldnt worry about it at all.....
once you start putting the pipes in you figure out exactly where things go
Here's a picture if it helps:
See the item noted as 1... i've never seen an AEM CAI have a spot for this sensor.
But his ECU is modified and he is now running OBD1. Can we ignore this sensor?
If you don't have a bung for the IAT, get one and put it in.
Shawn
hrm... well I don't know what to do now.
Well here's an AEM CAI system on a 6th gen Si. It appears that there's 2 spots.. one for the breather and the other for the IAT thingy.
[Modified by skafia, 10:39 AM 8/27/2002]
Zaff04
Feb 22, 2013 01:25 PM
OneSickJDMBB6
15
Jun 15, 2005 07:32 PM
TypeRInNeed
Dec 28, 2001 10:07 AM
