Do i have the right size piston for my bore?
Old Aug 15, 2009 | 08:49 AM
user 98292739's Avatar
Default Do i have the right size piston for my bore?
So i am replacing two pistons cause well they melted...
anyway i ordered (2) 75.5 cp pistons. I received them and i was wondering before i start tearing them apart that they are right.
I meassured them really quick and from side to side to meassures around 74.83mm does this sound right?
Old Aug 15, 2009 | 03:04 PM
jdm602's Avatar
Default Re: Do i have the right size piston for my bore?
if you ordered 75.5mm pistons they should mic almost to 75mm. the bore you need to bore it would be around 75.5mm depending on the piston to wall clearence you want.
you measuring them correct? 1/2" up the skirt?
Old Aug 15, 2009 | 05:20 PM
hmmmm i didnt meassure it correctly.
so i meassure them 1/2" from bottom up? didnt know that.
this is the spec sheet i got with it. according to the number it is the correct item.
Old Aug 15, 2009 | 07:26 PM
jdm602's Avatar
ahh there you go. it even says on the sheet to measure 0.5" up from bottom of skirt. anyways, now you just gotta get the block bored out to the right spec. if i were you i would bore it over 0.004" instead of 0.0035" but thats just imo.
xjdmjunkiex
Feb 28, 2011 08:26 PM
d16dcoe45
Oct 22, 2006 11:38 AM
Yambor
Apr 29, 2005 10:55 PM
phase12gsr
Nov 26, 2003 10:52 AM
B pwr
Mar 26, 2003 10:44 AM
