d series performance axle question?????
Old Aug 15, 2009 | 02:05 AM
kilerintegra's Avatar
Default d series performance axle question?????
I seen a 773hp sohc civic hb on youtube.com and it made me want to build my d series in my del just because no one else around me has one done. My question is where do you get axles to withstand that kind of power? Driveshaftshop.com only makes ones to hold up to 400hp. If anyone knows where I can get a set that wont snap off the line let me know. Also where can I get a good set of drag wheels? I found a couple but I would like some opinions from other people who have used some and what you guys would recomend. Thank you
Old Aug 15, 2009 | 05:06 PM
98civdx's Avatar
Master Detailer
Default Re: d series performance axle question?????
there are guys runing 600hp on nappa oem replacemts with lifewarrenty.
but try gator,
Old Aug 15, 2009 | 05:59 PM
single cam fan's Avatar
there are a lot of 10 sec sohc's running in the 10's on stock axles. I'm going to run stock axles and just keep a extra set in case of anything. They are cheaper than gator. Oh ya and the 700hp sohc is running on methaol and is a all out race car that runs 9's!
Old Aug 15, 2009 | 06:14 PM
Anon51's Avatar
the driveshaft shop makes custom axles but they're pricey. if someone's got the hook up say it loud. hehe
Old Aug 15, 2009 | 06:17 PM
98civdx's Avatar
Master Detailer
also i forgot to add, putting race axles in a car, turns the trannsmisson into the weak link so instead of breaking axles, you guessed it you get to replace trannys.
so i dont know about you but id rather spend 200 on 2 axles break theml, take them back and get new ones for free.
Old Aug 18, 2009 | 12:46 AM
You have a good point. I am getting an lsd put into the tranny and I have carbon syncros so that should help it a little. The reason I was asking in the first place was because I have seen many people with 300hp hatchback sohc's that put slicks on at the track and broke axles at the tree, I am running slicks I have a jojo callos complete front end for an Ek converted to fit my del sol. I just don't want to get the motor done and drive an hour and a half just to watch my car break the axles before I even leave the tree.
Thank you for the feed back greatly appreciated it.....keep adding if you like Im always open to new ideas, opinions, or straight facts and I will keep everyone up to date on the build
2x0
Transmission & Drivetrain
Mar 8, 2017 09:09 AM
H2BSTUPID
Feb 18, 2009 03:21 AM
95civiccpdx
May 1, 2008 11:02 PM
EgSalad
Mar 31, 2008 09:23 AM
kuja396
Aug 30, 2007 08:21 AM
