fuel gauge + radio issues
Old Aug 15, 2009 | 01:27 AM
wannabe mechani's Avatar
New User
Default fuel gauge + radio issues
Hi,
I had some issues with my 97 EX (manual transmission). I couldn't start it anymore. First I thought it was the starter, but the starter was ok. Then I assumed it was the ignition switch. No it wasn't. Then I found out it was the little plastic pad (PAD, PEDAL STOPPER) on the clutch pedal that was broken off. What a pain in the ***. This took me about 6 hours to find out/repair. Worst thing is, that the same part broke off on the brake pedal (causing the brake lights to stay on and therefore draining the battery) just a month ago and I should have checked this part first.
Anyway, now my fuel gauge is not working and there is no sound from the radio/cd. While fixing the starting problem I twiddled with the cables under the dashboard next to the fuse box. I guess that I've disconnected something. I will check the fuses later today. I have read here that the control unit in the dash light dimmer might be the culprit, but my dash lights are working.
Any ideas?
Thanks in advance
Old Aug 15, 2009 | 07:19 AM
Former User's Avatar
Default Re: fuel gauge + radio issues
Radio: Check fuses 28, 30, and 47.
Old Aug 16, 2009 | 03:15 AM
New User
thanks ron!
i checked the fuses and they look ok.
but i will replace them anyway, just to make sure.
is there any other place between sending unit and fuel gauge that might be disconnected?
and where is that access panel in the floor? i have a 2 door.
thanks
kresi
Old Aug 24, 2009 | 04:12 AM
New User
fixed it!
the connector left of the fuse box was not plugged in.
Old Sep 5, 2009 | 01:18 PM
ONE*SICK*FERIO's Avatar
Originally Posted by wannabe mechani
fixed it!
EDIT: did fix the fuel sending unit...?
DEPintheCurve
Feb 22, 2018 03:35 AM
Dr.Fixit
May 18, 2014 08:05 AM
civicguy1xxxxx
Jun 3, 2004 09:52 PM
Patch
Apr 17, 2003 04:05 PM
