skunk2 TB gets stuck even at 5.5k. unless i flick the pedal
Old Aug 14, 2009 | 07:42 PM
Dead CIVIC's Avatar
Veteran: Army
Default skunk2 TB gets stuck even at 5.5k. unless i flick the pedal
what can i do to fix this. i just went to walmart and other stores with parking lots and that **** is anoying. It gets stuck anywere2.5-5.5 and i have to flick the pedal for it to settle. i heard this is common. what do you guys do?
Old Aug 14, 2009 | 07:51 PM
Thizzed Out's Avatar
Default Re: skunk2 TB gets stuck even at 5.5k. unless i flick the pedal
might want to clean your throttle body with some cleaner. If that doesn't work theres a stop screw that you can adjust on the TB (adjust upwards), which is located under the spring.
Old Aug 14, 2009 | 08:13 PM
Dead CIVIC's Avatar
Veteran: Army
there is gotta be a DIY for these. i've heard this is common.
Old Aug 14, 2009 | 08:14 PM
raidacaipo's Avatar
I heard of alot of people having this problem with the skunk2 tb including a friend of mines...
Old Aug 14, 2009 | 09:47 PM
mortificationrock's Avatar
Try doing what THIZZED OUT said
Old Aug 15, 2009 | 09:50 PM
Dead CIVIC's Avatar
Veteran: Army
that bolt is all the way down. any other ideas?
Old Aug 16, 2009 | 04:54 AM
Anon51's Avatar
has anyone thought maybe its their Throttle cable? just throwing it out there. i'v never had a skunk2 tb.
Old Aug 16, 2009 | 07:40 AM
92ehatch's Avatar
i had this problem with an STR throttle body.
i took some 600 grit sandpaper and sanded the throttle body a LITTLE BIT around the top and bottom where the plate contacts it.
it fixed my problem.
notice LITTLE BIT. this may not be your problem, but it was with mine
Old Aug 16, 2009 | 09:39 AM
well there's your problem, you have to adjust it upwards til it doesn't stick.
Old Aug 16, 2009 | 09:42 AM
Hmm well if the TB cable was to tight it wouldn't close the butterfly all the way. Not closed = not sticking.
Old Aug 16, 2009 | 10:02 PM
Dead CIVIC's Avatar
Veteran: Army
i thought about doing that, but first i'll shorten that spring that takes it back so it has a stronger pool.
Old Aug 16, 2009 | 10:44 PM
fastrxu's Avatar
This is common even on stock tb's
I had this problem on a y5 and on my b18.
SiR-T
Feb 13, 2008 12:22 AM
19992civichatch
Jan 19, 2007 04:24 PM
Spectrum24x
Feb 12, 2006 04:29 AM
bootlegtrader
Oct 19, 2005 08:15 AM
asefi944
Apr 11, 2005 09:43 PM
