Coilovers ride hard
Old Aug 14, 2009 | 07:31 PM
toshko321's Avatar
Default Coilovers ride hard
hey guys, i installed coilovers on my civic the other day, i dropped it around 3 inches, which is a reasonable drop, and for now when i go over some things in the rode, it bounces in the back, do u think it will reduce a bit after a while when the coils get used to the car or somethin, idk
Old Aug 14, 2009 | 08:01 PM
chinochanginc's Avatar
Default Re: Coilovers ride hard
are you on stock shocks? three inches is alot.. it also depends on the spring rate.. i would raise it up and inch and see if it rides better
Old Aug 14, 2009 | 08:02 PM
egsleepercivic's Avatar
are the shocks adjustable, you may try to set them softer, otherwise your SOL, if your on stocks shocks thats a problem as well with a 3 inch drop
gl
Old Aug 14, 2009 | 08:07 PM
toshko321's Avatar
well i couldnt tell how much i dropped it, they are adjustable, i think i did around 2.5 im not sure but u can see some pics in my garage on the left, its not THAT low
Old Aug 14, 2009 | 08:25 PM
thumper64's Avatar
Eh, looks about like 2 inches. How old are your shocks?
Old Aug 14, 2009 | 08:27 PM
what kind of shocks and what kind of coilovers, and what are your spring rates ?
we need more info
Old Aug 14, 2009 | 08:38 PM
toshko321's Avatar
idk my springs and my struts are stock, BUT my mechanic said that they are perfect, i should have no problem, but idk what my spring rate is
Old Aug 14, 2009 | 08:52 PM
jdmwannabee's Avatar
wait what? springs and struts stock? just coil over sleeves? it's going to ride hard. sorry
Old Aug 14, 2009 | 08:53 PM
Jdm John's Avatar
There is your problem. Get some different springs. And how can your springs be stock and you lower it?
Old Aug 14, 2009 | 08:55 PM
EL Vap133's Avatar
Get better shocks, believe us!
Moto-mac's Avatar
did you trim or remove the rubber bottom out snubber when you installed them?
Old Aug 14, 2009 | 08:57 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Well your problem is that you drop your coilovers too low and your stock shocks can't handle lowered springs/coilovers.
What kind of coilovers is it?
Get aftermarket shocks and get a 4 wheel alignment.
Old Aug 14, 2009 | 09:02 PM
if they are stock they are not coilovers
gl
Old Aug 14, 2009 | 09:03 PM
Arthas's Avatar
You guys are making this more complicated than it is haha.
He got cheap sleeves and he slapped them on OEM shocks. OEM shocks cant handle that large of a drop. Im guessing these are the OEM shocks from factory, so they were already blown, but you cant really tell with stock springs. Bouncing=blown shocks.
Get some Koni Yellows, Tokico Illuminas, or Skunk2 shocks. People are aggressively lowered with those and they have no complaints.
Next time dont go cheap on your suspension please.
Old Aug 14, 2009 | 09:41 PM
forcefedferio's Avatar
listen to this guy here ^
I'm willing to bet a paycheck that the description for those coilovers didn't read "once installed, your civic will have the ride characteristics of a brand new cadillac, for only $29!"
Old Aug 14, 2009 | 09:52 PM
98civdx's Avatar
Master Detailer
i bet you have no name peices of ****, throw them away.
but if they arent normally with slip on coilovers they ride like total crap intell the setlle, at least my skunk2's did, now they are great,
DONT PUT PARTS ON YOUR CAR THAT YOU DONT KNOW WHAT THEY ARE!
Old Aug 14, 2009 | 10:59 PM
Arthas's Avatar
Those generic coil over sleeves arent that bad. Ill admit, they do ride pretty stiff but they are decent. As long as you pair them with new shocks you should be fine.
Old Aug 15, 2009 | 01:58 AM
immajackuup's Avatar
f1 vtec
Suspension & Brakes
Feb 6, 2005 07:14 PM
jspec-integ Ls
Sep 10, 2003 10:54 AM
RJx
Aug 19, 2003 10:21 PM
-iLLuZioN-B18C1
Aug 11, 2003 02:42 PM
Duck Sauce
Dec 21, 2001 07:58 AM
