build question...
i have an old wagovan. with a swapped d16z6 in it. im looking to run a turbo setup. and i was gonna ask how many pounds of boost i should run on stock bottom and top end. i was thinkin somewhere around 9 or 10lbs? anyone have any input?
That entirely depends on what turbo you are using.
turbo flow rate is a variable that has to be determined before the pressure of a fixed volume can be computed.
6 psi from a GT3586r is a whole lot more air than 6 psi from a gt1241.
and welcome to honda-tech..
GoldTeeth
Jun 8, 2011 12:43 AM
