What am I looking at?
Old Aug 14, 2009 | 03:47 PM
shutuprichard551's Avatar
Default What am I looking at?
What am I looking at here? and how would I go about fixing it? Its right behind the front right tire.
Old Aug 14, 2009 | 03:50 PM
p nut's Avatar
Default Re: What am I looking at?
That's the CV Boot. Already torn in half, so you can do one of two things. Take the stock one apart and rebuild it yourself.
OR, get a new one (I suggest this). They're around ~$90 or so new. I'd suggest against remanufactured ones, since others have had bad luck with them. Get brand new ones. Got mine from Autozone, but I think Checker's/O'Reily's has them cheaper. NAPA is good, too. They all should have lifetime warrantees, so if this happens again, you get a new one for free.
Old Aug 14, 2009 | 03:55 PM
How would I go about getting it on there? and do I need to put more grease in it? if so what kind?
Old Aug 14, 2009 | 04:01 PM
i drive a honda's Avatar
to rebuild it yes, it comes with a boot, clamp and axel greese.
if you take the big nut off under the wheel (one with a cotter pin on it)
IIRC its a 32MM socket, and you dis connect the LCA (pickel fork or craftsman socket wrench trick) hit the axel end (where the big brass nut was, don't break your trans housing, break the axel you're trading it in anway) it should move out with little to no resistance, if it is stuck GENTLY pry with the pickle fork,
to rebuild it remove the outer housing, tke he outer boot rebuild kit you have ($20) remove the old one with boot clamps clean greese, repack bearings (if they did't fly off the freeway) and replace.
its more work than just getting a new one.
Old Aug 14, 2009 | 04:10 PM
BryanM.'s Avatar
Resident Gearhead
OP this thread is a great help to anyone who has not replaced an axle before:
FAQ: Axle Replacement Tutorial With PICS!
Old Aug 14, 2009 | 04:17 PM
Do I need a new axle or just a new boot?
Old Aug 14, 2009 | 05:06 PM
p nut's Avatar
Just get a new axle. The cv joint has already been contaminated by dirt and grime already.
Old Aug 14, 2009 | 09:08 PM
new boot for sure, but we're telling you a new axle is cheaper and easier.
Old Aug 14, 2009 | 09:11 PM
^XpLiCiTxX^'s Avatar
correct answer
StaticEJ8
Feb 28, 2018 11:08 PM
Bluee9903
Jul 22, 2016 11:52 AM
SilverCVCC
Apr 27, 2016 05:00 PM
manny81
Dec 15, 2008 06:03 PM
