Throwout bearing seized? Need Pro-tips!
Old Aug 13, 2009 | 05:43 PM
jining's Avatar
Default Throwout bearing seized? Need Pro-tips!
Hello! I swapped a ZC into my si hatch a few weeks ago. I was missing an exhaust piece so I had to wait for that to come before trying to start it up and drive it. It starts, but the throwout bearing seems to be seized causing the clutch to be disengaged.... I took off the clutch cable and I can move the arm up and down an inch or so, it moves very easily.
Im assuming im going to have to pull the motor/tranny again to remedy this. Any pro-tips on taking the tranny out without pulling the whole motor? Or is it not worth the trouble.
Thanks,
Aaron
Old Aug 13, 2009 | 06:13 PM
jining's Avatar
Default Re: Throwout bearing seized? Need Pro-tips!
Never mind: I am retarded. The axles are not in the tranny all the way, they stick out about 1" on either side.... hopefully all is well once I get them seated in there properly.
How much force is required to move the clutch engagement arm to push the throw out bearing in? Trying to do it by hand...
Old Aug 13, 2009 | 08:23 PM
Sl1ck09's Avatar
does it even go into gear? doing it by hand is hard much easyer with the clutch pedle u can tell from steping on ur pedle if not then ur throw out bearing is posible seized and may need some lube. hope this helps
Old Aug 13, 2009 | 08:32 PM
jining's Avatar
I got the clutch arm to operate by hand and push down the pressure plate, takes like 50+ pounds of force, but I dont think its seized.
So my axles look like this...: this isnt normal right? Sticks out like 3/4"
I loosened the axle nut and I can push the axle in all the way, but then the threads for the nut are not showing.... if i tighten the nut, the axle just pops out again wtf... These are new axles I got from napa... according to their website they are the right ones for the 1.6.
Old Aug 13, 2009 | 08:41 PM
Sl1ck09's Avatar
it shud be seated all the way. just give it a good pull and push thats how i get my axles in.
Old Aug 13, 2009 | 08:47 PM
jining's Avatar
Yea i did that, i got it all the way in, but then there are no threads to thread the nut on....... its as if the axles are too short? wtf..
Old Aug 13, 2009 | 09:17 PM
Sl1ck09's Avatar
you may have put the on the wrong side. shorter on driver side and longer on tranny side
Old Aug 13, 2009 | 09:18 PM
BiG ChOr!Zo's Avatar
i had that problem with my car after i put in a different tranny...you might have a different tranny too and need to swap around your old hubs...!!!
Old Aug 13, 2009 | 09:35 PM
jining's Avatar
WELL I loosened the axle nut, then then pushed the cv joint in more and tightened it. Seems to be sitting in there further now. I started the car on jackstands and the wheels turn in gear, so thats good.... ill continue testing tommorow as my neighboors will get pissed.
Is it normal that I can put the car in gear and roll the car easily?
Old Aug 19, 2009 | 08:34 PM
Sl1ck09's Avatar
did you solve your problem?
Old Aug 19, 2009 | 08:41 PM
jining's Avatar
I believe so! Seems to go in 1st as well as reverse in my driveway :D havent test drove yet because my tabs expired. Ill go take it to emissions perhaps tommorow.
Dobird78
Oct 10, 2013 06:25 PM
Civic Hybrid
Jul 31, 2006 01:18 PM
bambbrose
Dec 12, 2004 10:17 PM
doublejz
Mar 9, 2004 01:19 PM
AzntaggeR
Feb 18, 2003 06:01 PM
