D15B8 to D15B
Old Aug 13, 2009 | 12:18 PM
jonny197's Avatar
New User
Icon2 D15B8 to D15B
I didn't find any other thread on the D15B8 to D15B swap so I started this.
I currently have a D15B8 in a 95 CX Hatchback that I was planning on having rebuilt. I have a blown head gasket, fried piston rings, and need a new clutch. Plus it has 200k+ miles. Instead of having this engine rebuilt I am considering getting a D15B swap (includes tranny) from Osaka JDM Motors.
I am not doing a swap for any other series, I can't afford to go to a B or H series, so I am looking at a simple D swap. I called the importer and it has the full harness as well. If I get the D15B would I need anything else besides the P08 ecu?
Thanks in advance guys.
Old Aug 13, 2009 | 12:35 PM
batallic's Avatar
Default Re: D15B8 to D15B
wiring up vtec
Old Aug 13, 2009 | 12:37 PM
jonny197's Avatar
New User
For that I would need to just run a wire from the VTEC solenoid to the ECU right?
If I cannot find a P08, is there any other ECU that I can use? Also, would I need to modify it at all?
Old Aug 13, 2009 | 12:41 PM
kaiba's Avatar
Scratch out the "8" and instead "D15B".
Old Aug 13, 2009 | 12:49 PM
jonny197's Avatar
New User
Sorry, but I don't understand
Old Aug 13, 2009 | 01:08 PM
xwhitchx's Avatar
p28, and get a new vtec solenoid , and some other wiring
Old Aug 13, 2009 | 02:29 PM
MWLW20's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/wiring-vtec-1650793/ that will help with wiring VTEC. When I did it I used the original harness and cut the black tape/wrap covering JDM harness to get the VTEC solenoid and VTEC Pressure switch.
Old Aug 13, 2009 | 03:01 PM
jonny197's Avatar
New User
Fantastic. Thanks a lot for the help guys, definately getting that engine!
Old Aug 13, 2009 | 06:18 PM
batallic's Avatar
while yur at it change TB& water pump
Old Aug 13, 2009 | 06:40 PM
honda_hackett's Avatar
its a joke homie. you dont need anything except a lil elbow grease aka wiring vtec which is a cake walk.
Old Aug 13, 2009 | 11:08 PM
jonny197's Avatar
New User
Oh! I didn't get it before
Thanks a lot guys. Should I also post in this thread if I have any issues with the swap?
Old Aug 13, 2009 | 11:26 PM
thumper64's Avatar
You may need an upper driver's side engine mount for a D16Z6 if your D15B doesn't come with it. Autozone has them for like $20.
Timing belt, water pump, idler pulley, and I'd suggest main seals and a new clutch, obviously.
Take the intake off the new JDM engine and clean it out well. It will probably be really nasty from the junky Japanese gas.
Old Aug 14, 2009 | 02:59 AM
erikwithak's Avatar
get the right harness and you wont have to wire vtec and if you need one of those ecus i wanna say i have two sitting in the garage
chevmaro
Mar 27, 2011 01:31 PM
ATK_Tae
Nov 15, 2008 05:32 AM
GhostInTheShell
Feb 18, 2006 03:06 PM
EGPHANTOM
May 14, 2005 12:06 AM
