92 Accord with Idle Problems
Old Aug 13, 2009 | 09:12 AM
drittle's Avatar
New User
Default 92 Accord with Idle Problems
My 92 Accord (2.2, 5 speed) stalls when coming to a stop. If you can hit the gas while stopping, sometimes you can save it. It has 230k miles, and none of the sensors have been replaced. I am guessing it may be a sensor, but I don't know where to start. Any help would be greatly appreciated.
Old Aug 13, 2009 | 09:24 AM
96redexcivic's Avatar
Default Re: 92 Accord with Idle Problems
I will start out with throttle body clean it with throttle body cleaner couple bucks use a tooth brush wipe it good, also theres a IAC sensor that get dirty sometime need cleaning also in throttle body, It's possible you may need tune up plugs,wires,cap,air filter and rotor, but do the cleaning first and try it. Good Luck.
Old Aug 13, 2009 | 09:36 AM
drittle's Avatar
New User
Thanks. IAC? Is this the throttle body sensor?
Old Aug 13, 2009 | 09:56 AM
j3wman's Avatar
IAC = Idle Air Control, are you on cb7tuner? we have a write up on how to fix that in the DIY section.
Old Aug 13, 2009 | 10:02 AM
drittle's Avatar
New User
Sorry, I don't know what cb7tuner is? I am definately interested in the write up, I like doing my own work, just not real good with sensors. How do I get to the write up?
Old Aug 13, 2009 | 10:37 AM
gqstatus05's Avatar
cb7tuner is a website. Google it and sign up. It will help you out. They have a write up with pictures as well. It's an easy job. The IACV should do the trick. Clean that out and you'll be fine.
Old Aug 13, 2009 | 10:41 AM
Bwill9886's Avatar
Definitely check the Throttle Position Sensor voltage as well. If you do a google search, plenty of writeups are out there.
The TPS and IACV are two of the most common things to check when experiencing these symptoms.
Old Aug 13, 2009 | 11:43 AM
drittle's Avatar
New User
Thanks for all the help.
Old Aug 13, 2009 | 01:27 PM
j3wman's Avatar
cb7tuner is like the bible for our cars
Old Aug 13, 2009 | 02:41 PM
gqstatus05's Avatar
Good Luck.
Wrench271
Feb 12, 2017 04:06 PM
Wrench271
Feb 12, 2017 03:00 PM
Nonio
Aug 26, 2010 12:02 AM
Mr_Si-R
Sep 6, 2007 10:51 PM
tulsa442
Oct 11, 2004 01:41 PM
