Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
check engine light
Old Aug 12, 2009 | 05:18 PM
tsdenny's Avatar
Default check engine light
how do i pull the code? 2007 civic lx sedan
Old Aug 12, 2009 | 05:56 PM
tsdenny's Avatar
Default Re: check engine light
for the code
U0155 FCAN Malfunction (Gauge Control Module-ECM/PCM)
how do i fix it
Old Aug 12, 2009 | 06:21 PM
DBAl's Avatar
Is it still under warranty? If so, there is your answer.
You can also check the connections on your gauge cluster to make sure they are tight. I have heard of that code popping up from loose connections.
Old Aug 12, 2009 | 06:48 PM
L337_L0gan's Avatar
have you don't any custom wiring. interior/exterior lighting? anything like that?
i searched and found someone with a fit that threw the same code and his interior neon was the cause
Old Aug 12, 2009 | 06:51 PM
tsdenny's Avatar
everything is stock
Old Aug 15, 2009 | 03:14 AM
vladd's Avatar
as already mentioned, if the car has a warranty the first place i'd go to would be the dealership; that's what the warranty is there for.
LoGaN-VanG
Honda Civic (2001 - 2005)
Jul 1, 2009 08:18 PM
skaternak
Oct 29, 2008 01:40 PM
SOHC_Brian
Mar 25, 2004 12:14 PM
MaNyFacEs
Dec 30, 2002 04:36 PM
