Shift Linkage/Tranny Problem
Old Aug 12, 2009 | 12:59 PM
Finnish_EK_Race's Avatar
Default Shift Linkage/Tranny Problem
so today i put in my new exaust system and decided to take the car out for a ride.
its got a N/A d15b and it hasnt been driven in at least a month.
so i got it into first and redlined it to see how hard i could get it to pull nd i heard a pop and i lost acceleration,
i shifted and i got nothing.
now i plumb outta luck with a car that runs but wont drive,
any help?
Old Aug 12, 2009 | 01:08 PM
mouab18c1's Avatar
Default Re: Shift Linkage/Tranny Problem
what do you mean when you shifted and got nothing? not going into gear? car not accelerating?
Old Aug 12, 2009 | 01:43 PM
yeah i heard a pop....shifted into gear and put the gas pedal to the floor and got nothing, just a revving engine like i would if i was in neutral
Old Aug 12, 2009 | 02:05 PM
mouab18c1's Avatar
seems like something is not engaging like when a clutch is slipping
Old Aug 12, 2009 | 02:44 PM
so what do you think i did??
Old Aug 12, 2009 | 04:37 PM
please note* i had the engine run and i shifted into gears.....i did not need to use the clutch to shift gears. the gears didnt catch and the tranny made a whining noise like when u grind gears.
Old Aug 13, 2009 | 05:04 AM
any help??
Old Aug 15, 2009 | 11:08 PM
lilo_goki's Avatar
did you check if your axle's are still on, maybe one of em came out. that happens a lot of times. check it and respond back.
Old Aug 16, 2009 | 09:18 AM
where could it have pooped out from....?? behind the hub if the cotter pin broke?
or where the cav is? let me know...lol
Old Aug 16, 2009 | 10:09 AM
i checked it out lilo and i saw both cotter pins under the hub looked fine and i pulled out the axle and the passenger side was a little wobbly but nothing that i thought was bad.
i think i gotta replace the clutch....cause i dont have to push the clutch in the shift...which is not good at all....but when i have the engine running and i shift higher and higher the engine whines like im grinding gears....idk if it is the clutch is blown but thats what some other people on club civic are saying.
Old Aug 16, 2009 | 09:08 PM
lilo_goki's Avatar
the part where it goes into the tranny, not the hub. also, if you put it in gear and it doesn't go but hear's a grinding noise, then it's your clutch.
Old Aug 17, 2009 | 06:28 AM
ok its fine at the tranny, but i can put it into gear but i dont need to use the clutch pedal to be depressed for it to shift.
Old Aug 17, 2009 | 06:51 AM
kyden's Avatar
you sure you didn't snap an axle?
Old Aug 17, 2009 | 01:23 PM
yeah i didnt snap an axle....its rolls just like its driving. so ik the axle is fine.
Old Aug 17, 2009 | 07:56 PM
mouab18c1's Avatar
so your driving and shifting with no clutch right? from reading your postings. i think you f'd up your clutch or pressure place or something worse
Old Aug 18, 2009 | 06:28 AM
well no....the car wont drive....but it shifts with no clutch, and yes the engine turns over and its fine but i think its the clutch too.
Old Aug 19, 2009 | 09:47 AM
mouab18c1's Avatar
time to take it off and inspect it..best way to do it
Old Aug 19, 2009 | 12:03 PM
what should i be looking for in regards to scoring? anything like that....?
Anyone wanna donate an ACT extreme 96 civic d-series 6-pad racing clutch kit to me??
i'll tattoo your name on my face!
hannslebo
May 6, 2009 04:37 AM
CD5 Jeebies!
Aug 13, 2007 02:05 PM
graftuner34
Feb 28, 2007 12:56 PM
Ge-money
18
Nov 18, 2006 05:43 PM
deftones0817
Nov 30, 2002 05:49 AM
