Need Help ASAP please
Ok, I got all but 2 of the bolts off to take out the strut/coilover assembly but the ones giving me trouble are the pinch bolt on the fork and the lower bolt on the fork...i got the nut off of that but the bolt won't come out. I thought maybe it screwed out but i turned and turned and it went no where but it still has alot of tension...is it supposed to just slid out? Any ideas?
[Modified by Civic89, 9:02 PM 8/25/2002]
You have to relieve the tension off of that bolt by pushing up and down on the lower control arm while pulling the bolt out. Or you can take a hammer and screwdriver and drive it out from the backside of the bolt, which is what I do most of the time, it is the easiest way.
So it should just be sliding out then right?
Also, I need to remove the upper ball joint from the bar that's mounted to it. I've heard there's clips that hold them in and i've heard you can just knock them apart with a ball joint separater...which is it? thanks for your time and info!
Are you using a shop manual? If not, go buy one right now. It'll save you time from running to the computer, posting, and then waiting for us to help. All your answers can be found in a $13 book that's available at any auto parts store.
I have that 13 buck manual and it don't help with s***! That's why i'm here.
I got the ball joint off....all bolts are loose except pinch bolt for the coilover fork and the lower bolt still isn't sliding out...I've tried suppoorting it still to no avail. Any suggestions??? Please?
Shocka1998LX
Aug 27, 2004 12:29 AM
