brake lamp problems!
Old Aug 11, 2009 | 07:01 PM
prototype2's Avatar
Default brake lamp problems!
I have a 99 civic ex. Just this past week, i notice that my brake lamps weren't lighting up when i apply the brakes. However, my parking/running, signal, and reverse light seems to be fine. I checked my fuse and it was completely fine too. So i decided to replace the light bulbs. When i installed it, i applied the brakes and there was light. I checked the brake bulbs and the bottom wire of the bulb was burnt or corroded. it was like that when i first took out the previous bulbs too. could i have a short circuit? help me, this is getting ridiculous. i do not want a dumb a** ticket for this.
any help will help!
here's a picture of my brake light bulb where the brake wire is burnt/corroded.
look closely and you can see the burnt/corroded on the left side of the bulb in the picture.
Old Aug 11, 2009 | 07:43 PM
prototype2's Avatar
Default Re: brake lamp problems!
bump!
Old Aug 11, 2009 | 07:50 PM
Former User's Avatar
Are you sure that you are installing the correct bulbs?
Old Aug 11, 2009 | 07:56 PM
prototype2's Avatar
yes i am. (not that i know of)
Old Aug 11, 2009 | 08:00 PM
At the Grn/Wht wire attached to the bulb receptacle, what voltage do you measure when you press the brake pedal with and without the engine running? Any other electrical problems?
Old Aug 11, 2009 | 08:06 PM
prototype2's Avatar
i haven't measured it out yet but my horn is out too. it's strange.
Old Aug 11, 2009 | 08:16 PM
This is interesting because the horn and brake lights are on the same circuit. Check whether both Wht/Grn wires attached to the horn relay have battery voltage.
Old Aug 11, 2009 | 08:23 PM
jdeemseerx's Avatar
so you put in a new bulb and it burnt out after how long? did your horn stop working at the same time as your bulb problem? if its not the fuse i believe its labeled as STOP then you have to find a schematic and see where those circiuts share a connection..check for corrosion or burnt wires.. that would be my first step
Old Aug 11, 2009 | 08:48 PM
prototype2's Avatar
it died instantly when i applied the brakes. i think the horn prob stop working while the lights died too.
Originally Posted by jdeemseerx
...then you have to find a schematic and see where those circiuts share a connection...
Old Aug 11, 2009 | 10:42 PM
prototype2's Avatar
dang. sorry but it looks confusing. i'll try to trace them wires.
Old Aug 12, 2009 | 11:41 AM
prototype2's Avatar
bump
Old Aug 13, 2009 | 01:20 PM
prototype2's Avatar
bump
Old Aug 13, 2009 | 02:14 PM
Do you have or can you get a multimeter?
Old Aug 13, 2009 | 09:30 PM
prototype2's Avatar
i think i might have one but it's a very old one.
Old Sep 18, 2009 | 08:08 AM
prototype2's Avatar
got it. the stupid dumbass horn fuse blew.
professorman
Oct 27, 2013 06:28 AM
stranskydesign
Honda CR-V & Element
Aug 3, 2010 05:55 AM
mfniazi
Dec 10, 2009 12:13 PM
LudeJdm
Aug 16, 2006 08:09 PM
951dc5
Nov 18, 2004 02:42 PM
