does anyone know what to us to clean off window tint
i just purchased a 91 civic and the tint in the rear started to peel and bubble so i ripped it off, now there is the sticky residue left over. anyone has suggestions for getting that sticky residue off. thanks
I do signs and graphics. we use whats called Rapid Remover... it basically just breaks down adhesive. spray it on and scrape at it with a blade and then after its all off, clean your window with windex or whatever.
http://www.rapidtac.com/products/remover.html
You can usually pick this up at a sign supply shop. There may be other things out there specific to tint but this is what we use for decal adhesive. You could also try a solvent called naphtha. You can pick that up at home depot or at a paint store like sherwin williams.
Or Hell, try rubbing alcohol
m0dr0cker
16
Oct 21, 2003 09:55 AM
