a/c problem
so when im driving and i rev past 4k something starts hissing in my car and then the a/c doesnt blow cold for a few seconds until the hissing goes away. what do you think it is?
not at the moment i live in a gated appartment complex. its weird i know its on the driver side. and only happens when i rev past 4k then my ac stops blowing cold air. but once i let it rev down to around 3k and under it stops
well i havnt actually checked it out yet. im pretty sure you can hear it from the outside but when im driving it sounds like its coming either from the air vent. on the driver side or underneath where the fuse box is. ill try to pin point it better tomorrow.
so i was looking at it today. i rev the car up to about 3.5k 4k with the a.c on and the clutch on the compressor disengages. slowly letting the rpms down the clutch starts spinning again and this is what is causing the hissing noise. once it grabs it stops hissing. could this be a sign of a bad or going bad ac compressor?
not when it disengages. when it tries to engage again. here is exactly how it goes. idle i turn a/c on its fine blows cold. i drive or sitting at idle i rev to around 3.5k-4k the clutch disengages i let off the gas and it tries to engage again. when it trys to start engaging it makes a loud hissing noise i can hear. i watched the compressor. once it engages again the hissing stops and the cold air comes back. but once it starts hissing its just blowing air from outside i guess. no cold. is it normal to disengage around 3.5k-4k? how could i test it o what ever you recommend me doing?
it just started doing it in the last 3days maybe. i got on the highway when it was raining and i kept hearing it but i just thought it was me driving through water. i was driving pretty fast on my way back home over 100mph.it was dry by then and i started hearing it again. now when im just driving around town i hear it all the time.
roghax85
Honda Civic (2001 - 2005)
Feb 22, 2013 12:20 PM
mrivera
May 27, 2008 09:08 AM
