What else besides springs and shocks do i need to lower my gsr?
I got my KYB AGX's and i am going to install them with hr sports. My question is what else do i need to install them (i.e. bumpstops, washers, top caps, dustcovers). Do i just take all the stuff off the stock assembly and put it on the new shock and spring???
Thanks in advance
- Chris
Thanks in advance
- Chris
dunno about your springs, but when I installed my GC's with the AGX, we re-used the bumpstops and dust covers, but we cut them quite a bit.
Yes, you use everything that was on the stock assembly. Also with the AGXs (i have them too) there are instructions and a few washers and a nut that you have to use. You might want to invest in a camber kit too. From my experience, whatever lowering springs you get, you have to adjust the camber so you dont get uneven wear. My brothers Eibach Prokit (only a 1.25" drop i think) even needed a camber kit.
[Modified by Honda Hick, 3:17 PM 8/25/2002]
how much do u cut the stops. what happens if u do not cut them?
sn00py415
May 17, 2007 12:20 PM
type Gendy
Mar 5, 2003 04:31 PM
