spring install question
Old May 19, 2006 | 12:04 PM
accord4door's Avatar
Default spring install question
if i install the neuspeed sport springs which i belive its a 1.8" drop at the front and 1.7 at the back, will i need a set of new shocks too and a camber kit??
Old May 19, 2006 | 12:09 PM
kbanks45's Avatar
Default Re: spring install question (accord4door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord4door &raquo;</TD></TR><TR><TD CLASS="quote">if i install the neuspeed sport springs which i belive its a 1.8" drop at the front and 1.7 at the back, will i need a set of new shocks too and a camber kit?? </TD></TR></TABLE>
Eventually you will need shocks, but the closer you get to 2 inch's on your drop, the more you will need a camber kit. I would go ahead and do it. That's cheaper then buying new tires every 4 months...
Old May 19, 2006 | 11:59 PM
bloodgulch's Avatar
Default Re: spring install question (kbanks45)
if you're going the DIY route-then replacing the shocks now will save hassle of having to remove everything in the future(spring compressor), and getting a camber kit will also save and money, but I would hook up the shocks and springs aline it and go from there, if your alignment is not totally out of whack, you might be good without the camber kit..good luck
-p.s. what car is this set-up going, and what does your rolling stock consist of..(stock wheels, 16's 17's..etc)
Old May 20, 2006 | 12:24 AM
Default Re: spring install question (bloodgulch)
its going into an accord 6 cyl. 4 door and it is going to be rolling on stock 15's for now
Old May 20, 2006 | 12:33 PM
lxaccord51oxl's Avatar
what if i have neuspeed race springs ready to be install. i think they are 2.25" all around. what type of shocks would you guys suggest? will the tokico blues be alright? im riding on 15 stocks on a 5th gen. and i looked for the spc camber kits and they are DUMBY expensive.
Old May 21, 2006 | 11:00 AM
Default Re: spring install question (lxaccord51oxl)
how about the kyb shocks? how are they compared to the tokico's? are they worth the price difference? keep in mind i just want the lowered look, im not gonna be racing this car, its all for show.
Old May 21, 2006 | 03:31 PM
d112crzy's Avatar
depends which kyb. there are 2:
the kyb gr2's and kyb agx
the gr2's and tokico's are pretty much the same, both a little better than stock replacements.
the agx is pretty good, i have them, but they are drop killers. the next best, imo, is the illuminas, then in 1st place is the konis.
Old May 21, 2006 | 10:03 PM
Default Re: (d112crzy)
what do u mean drop killerz?
Old May 24, 2006 | 01:53 AM
bloodgulch's Avatar
Even if you are going for show only you still want the ride to be functional, if you lower the car you change the dynamics (response to roads, elements etc..) I would suggest the tokico HP(blue) a shock better suited to lowering while not being to stiff, the Tokico Illumina(white) a worth the extra penny up front, and are adjustable to suit your needs. I have had three hondas and rolled tokico with each and they handled well and were suited to my needs. But definently upgrade your shocks...
Elemental
Sep 21, 2004 10:35 AM
Project99EK
Nov 15, 2003 08:57 AM
ilikemyaccord
Sep 5, 2003 10:04 AM
grngsr01
Aug 25, 2002 11:30 AM
p0pe
May 17, 2002 07:28 PM
