Can JDM B16 pass emissions????
Old Aug 11, 2009 | 09:14 AM
jdmcivicracer89's Avatar
Default Can JDM B16 pass emissions????
yo i got a oo ek coupe shell and i was trying to find a motor to swap in. i found a 2000 JDm B16a. he says ill pass emisions with it. i thought JDM motors cant pass emmisions in the US. am i right or is he??? thx
Old Aug 11, 2009 | 09:19 AM
EBPcivic2000's Avatar
Default Re: Can JDM B16 pass emissions????
i have a jdm b16a in my em1.. has all the usdm smog parts. it passed emissions..
Old Aug 11, 2009 | 09:21 AM
which smaog parts are u talking about??? like charcoal canister and all that??? or is there sensors ill have to add to make it pass?
Old Aug 11, 2009 | 09:31 AM
B18CivicEJ8's Avatar
You'll need to have your charcoal canister, your EVAP purge control solenoid, a VTEC solenoid with an oil pressure switch (it can be bypassed), and you'll need to bypass the CKF sensor since JDM motors don't have one:
http://ff-squad.com/wp/?p=309
Since EK civics are OBD2, you'll need to run a USDM OBD2 ecu to pass the scan test when you go do emissions. As long as you don't have any CELs, you'll pass. They typically don't do sniffer tests on OBD2 cars.
Old Aug 11, 2009 | 09:37 AM
arent the first 2 on the car itself not the motor??? so i cant use the vtec seleniod off the JDM b16?
Old Aug 11, 2009 | 09:38 AM
^^ this is correct to the best of my knowledge
Old Aug 11, 2009 | 09:51 AM
Old Aug 11, 2009 | 09:53 AM
we posted at the same time.. i was referring to the post above yours
Old Aug 11, 2009 | 09:54 AM
The cansiter is on your firewall, so technically, yes, it's on the car. The EVAP purge control solenoid is placed between the canister and intake manifold via vacuum lines and has a connector to send signals to and from the ECU. If the stock engine is still in there, you can re-use the EVAP purge control solenoid from the stock engine, it will work fine.
You can use the VTEC solenoid off the JDM B16, but the OBD2 USDM ECU will look for a VTEC oil pressure sensor which JDM solenoids will not have. You can bypass that, but I don't have a link to a write up I can provide you. You'll just have to search for it. Suffice it to say that all you have to do is cross the VTEC pressure sensor wire with the VTEC signal wire at the ECU.
Old Aug 11, 2009 | 10:22 AM
ahhh ok makes more sense now. thx
Bulli Kid
Apr 14, 2007 03:51 PM
guamie
Nov 2, 2006 08:50 PM
Noemotion_91DA
Jul 29, 2006 09:12 PM
dropd4door
Feb 12, 2003 06:21 PM
chefcris420
Jun 14, 2001 01:20 PM
