Can JDM B16 pass emissions????
yo i got a oo ek coupe shell and i was trying to find a motor to swap in. i found a 2000 JDm B16a. he says ill pass emisions with it. i thought JDM motors cant pass emmisions in the US. am i right or is he??? thx
Re: Can JDM B16 pass emissions????
which smaog parts are u talking about??? like charcoal canister and all that??? or is there sensors ill have to add to make it pass?
http://ff-squad.com/wp/?p=309
Since EK civics are OBD2, you'll need to run a USDM OBD2 ecu to pass the scan test when you go do emissions. As long as you don't have any CELs, you'll pass. They typically don't do sniffer tests on OBD2 cars.
You'll need to have your charcoal canister, your EVAP purge control solenoid, a VTEC solenoid with an oil pressure switch (it can be bypassed), and you'll need to bypass the CKF sensor since JDM motors don't have one:
arent the first 2 on the car itself not the motor??? so i cant use the vtec seleniod off the JDM b16?
You can use the VTEC solenoid off the JDM B16, but the OBD2 USDM ECU will look for a VTEC oil pressure sensor which JDM solenoids will not have. You can bypass that, but I don't have a link to a write up I can provide you. You'll just have to search for it. Suffice it to say that all you have to do is cross the VTEC pressure sensor wire with the VTEC signal wire at the ECU.
The cansiter is on your firewall, so technically, yes, it's on the car. The EVAP purge control solenoid is placed between the canister and intake manifold via vacuum lines and has a connector to send signals to and from the ECU. If the stock engine is still in there, you can re-use the EVAP purge control solenoid from the stock engine, it will work fine.
ahhh ok makes more sense now. thx
Bulli Kid
04-14-2007 03:51 PM
