Idle jumping from 1,000 to 2,000 RPM
Old Aug 25, 2002 | 08:30 AM
Sunrise City Rider's Avatar
Default Idle jumping from 1,000 to 2,000 RPM
My friend's 90 Integra LS is having idle problems...Its bouncing up and down from 1grand to 2grand and when you turn the AC on it drops to 1,000 RPM
He thinks its the Map Sensor and unplugged it to see if the problem changed...I told him that unplugging it will not show him anything but a check engine light and high idle...The fast idle screw is adjusted to the minimum and the problem persists...
Any help will be appreciated...The car doesn't want to stall at all, so I don't think its a vaccuum leak, plus we can't hear a damn thing leaking and we checked the visible vaccuum hoses and they are secure...
Thanks in advance,
Zee
intikab@cs.com
Old Aug 25, 2002 | 08:33 AM
VTECorona's Avatar
Default Re: Idle jumping from 1,000 to 2,000 RPM (Sunrise City Rider)
I've seen that happen to my friends prelude si. He had a vacuum leak and his idle kept pulsing from high to low. He put his finger over whatever was doing it and it stopped. Not sure if that helps but my .02.
blkspd5
22
Jan 27, 2020 11:55 AM
Nisif
Nov 26, 2011 07:22 PM
DC2andED6
May 9, 2009 02:55 PM
go2sleep
Jun 15, 2006 08:54 PM
